Sponsored by: CARiD
c/s button
Old May 15, 2010 | 05:36 PM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
c/s button
the manual says to select the c/s button that changes the transmission program only when in park. anyone know why this is and if there are risks to doing this while in drive/in motion?
Old May 15, 2010 | 06:53 PM
highroller550's Avatar
2010 e550 coupe , 2010 ML550
i've had the car since october and i press that button anytime i feel like it .... no problems yet :P
Old May 15, 2010 | 07:14 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
+1 ...
Old May 15, 2010 | 07:23 PM
Ninjaryder's Avatar
2010 E350 1999 Ninja ZX7R 2006 Ninja ZX10R
If you plan on keeping your car long term & trouble free always refer to the manual. I won't even look at C/S until the car is broke in (1000+ miles)
Old May 15, 2010 | 09:20 PM
DHI's Avatar
DHI
'10 ML550, 996 G T 3
+2
Old May 15, 2010 | 09:26 PM
ttoE550's Avatar
2015 GL450
Yeah, I do too. But be honest -- do you think pushing it makes any discernible difference? I honestly cannot feel any difference. Even the track testers at some magazine said the same.
Old May 15, 2010 | 09:55 PM
DHI's Avatar
DHI
Actually, yes.
Pulling off from a light in 1st instead of 2nd feels (and sounds ) very different to me. Subsequent shifts are just slightly crisper and occur at higher revs.
I just wished that it would save the last setting chosen, instead of resetting to "C" all the time.
Old May 16, 2010 | 09:38 AM
aeggroup's Avatar
Originally Posted by DHI
Actually, yes.
I agree.....
Old May 16, 2010 | 10:22 AM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
They recommend not changing the mode when driving because it alters the steering response, suspension, transmission shifting, etc. Theoretically if you were making a serious maneuver and you hit the button, it could cause you to lose control.
My thought is that if there was a serious risk, MB would program the button so that it could only be activated when the car is stopped (same as navi destination input). Changing the driving mode while in motion certainly will not damage the car in any way unless you hit something!
Old May 16, 2010 | 10:39 AM
DHI's Avatar
DHI
You are probably referring to other car makers or systems.
The W212 C/S button only changes transmission characteristics.
Old May 16, 2010 | 12:09 PM
whatever that button does. to me it make it feel like a new car. i love it.
Old May 16, 2010 | 12:41 PM
YYZ-E55's Avatar
Sorry - I was referring to the "dynamic handling" sport button found on the E-Coupe (and other MB models). The concept still applies as it relates to the transmission - if you're in sport mode in a fast turn and you shifted to comfort, the trans could upshift and change the weight balance, causing you to lose control. Not sure how many people are driving their non-AMG E saloons to the limit like that, but hey
Old May 16, 2010 | 03:40 PM
mg-E550's Avatar
Thanks for all the replies! I have had the car and have pressed it a number of times on motion, but just wondered if I was shortening the life of the tranny.
On the other point about noticing the difference, i definitely find that the car behaves differently both starting off (1st vs 2 d gear) as well as up and down shifting. In s the car holds the last gear much longer before upshifting and generally seems to downshift more quickly.
My only complaint about the system is that the shifts using the paddles in either c or s mode are too slow.
Old May 17, 2010 | 11:52 PM
ttoE550's Avatar
2015 GL450
Actually, yes.
I spent some time playing, and I don't see it. I confirmed several times that putting it in S mode does not automatically put in in 1st at takeoff. After sedate driving, stopping at a light, hitting the c/s button to put it in S, and taking off at full throttle, I still get a (near instantaneous) downshift from 2nd to 1st. Likewise, after some "spirited" driving, I could take off in C mode in 1st gear.
There is a corner I take every day. It's a nice wide 90-degree corner that can be taken at good speed. For fun, I typically accelerate hard at the apex. Whether in C or S mode, driving up to the corner in a sedate manner will give a downshift near the apex under acceleration (not ideal). In either C or S mode, driving "spiritedly" prior to the corner, the car is one gear lower and does not downshift (ideal). By "spiritedly" I mean kicking down the transmission two or three times before arriving at the corner. And the sound is glorious both ways under spirited driving.
Personally, I think this car is smart. I think you can be in C mode and make it behave like what I will call "a beast" by managing the throttle. (Maybe the E63 would then be a "wildebeast.") Likewise, in S mode it will behave like the same beast, also by managing the throttle. The potential difference, as much as I am able to determine, is that the S mode is perhaps quicker in moving to beast mode. But whether in C or in S, once the car is in beast mode, it is the same.
I find it reassuring that a test driver from Car and Driver Magazine also could not tell the difference.
http://www.caranddriver.com/reviews/...take_road_test
Old May 18, 2010 | 03:31 AM
christiaan's Avatar
E-550 Coupe 2010 SE
Exclamation
i really dont get what your talkin about, the 550 coupe, doesent have that CS button, it only has the M button....
Old May 18, 2010 | 09:47 AM
firefighter608's Avatar
2010 S550, '10 Road glide, '10 Sportster "48"
There is a sport button on dash near seat temp buttons on E550, lit is sport mode, off is default comfort mode
Old May 18, 2010 | 02:24 PM
gichundo's Avatar
07 CLK 350 gone...... 10 E350
didn't break the point to rev over 2000 RPM on my W212 yet... but from past experience through W209..... There was slight bump on acceleration and tone change on exhuast due to reving higher on gears.....
Old May 18, 2010 | 06:38 PM
DHI's Avatar
DHI
Thanks for the details. But do you feel any difference at all? I assume that the CS selection is confirmed on the dashboard screen?
I definitely feel a difference in my car.
Old May 18, 2010 | 11:20 PM
ttoE550's Avatar
2015 GL450
Yes, I do see the S on the dash when I push the button. As far as a difference between the two goes, I think I do see a slight difference in how quickly the car adjusts for spirited driving. In effect, pushing the button seems to say "we are about to take off" and if you confirm by indeed taking off, then the car responds more aggressively fairly quickly. In C mode, though, it seems that you have to do a little more to wake the car up (like kicking down the transmission a few times), and once you do the car is just as aggressive as it is S mode.
But if I am driving like a grandpa in C, switch to S, and continue to drive like a grandpa, I feel no difference.
Try it. Drive like a grandpa in both modes. Does the car feel any different? Then drive in a spirited fashion in S mode, switch to C, and continue to drive in a spirited fashion. Does the car suddenly seem more sluggish? For me, the answers are no.
Now I will admit that I typically switch to S on on-ramps to highways because I want the car to already be awake if I need to accelerate hard. In Washington DC it seems that many drivers like to race you to block your merge. My experience driving in Montreal (wonderful, wonderful city) is that the drivers are much friendlier and accommodating. I think it's the only place I've seen the zipper merge actually work!
OT: Do you ever get to Mont Tremblant? (north of Montreal) It has my favorite race track (won twice there several years ago), a great luge, and great restaurant ambiance, even if the food is mostly so-so. I highly recommend it. I'm not a skier, so I went in July each time.
Old May 19, 2010 | 09:21 PM
DHI's Avatar
DHI
Montreal drivers... relatively competent. Little use of turn signals, few/faded visible line markings on pavement, drivers expect fellow to be decisive in their driving and so few get offended when things happen quickly. In fact, slow indecisive drivers are frowned upon and cause more frustration than anything else. In short drivers here are generally awake.
Tremblant... I've done a few track events there in 96, 97, and 98. Awesome classic track. Flows well and is rewarding to drive. Never drove the track since it's slight redesign and resurfacing. You may remember it for it's abrasive surface making it nearly as quick in the wet.
C/S button... I'll keep playing that button with your comments in mind.
Cheers, fellow Merc owner.
David
Old May 21, 2010 | 08:40 AM
Tjdehya's Avatar
2023 AMG EQS
If you drive like grandma then the c/s button wont make a difference but if you step on the throttle a little harder and a little longer then the difference is obvious.
