Nightview assist/Infrared bulb removal
e350
The manual says simply to remove the bulb but the bulb is in some sort of casing. I have p2 package with the xenons. I'm switching out the low beams to 5000k and need to swap out the inners (infrared night view assist) as well.
Headlamp pic: e
Inside of housing:
I wasn't able to remove the clip with the two black wires, even though I think if removed it wouldn't solve the problem. I believe the casing protecting the bulb is drilled in but I can't be sure. Any input would be great. Thanks
Headlamp pic: e
Inside of housing:
2010 E550 4matic, 2008 MDX, 2011 335i Vert
Sorry I can't help with your original question.... But I am curious why you change the in fared bulbs? Are the different intensities of those?
I though I remembered seeing something about changing those in the manual but im sure you've already checked.
e350
The infrared is a basic H11 bulb, the color barely even batches the OEM 4250k headlamp. I'm hoping someone has an answer for this before I head to the dealership. I'll be doing the bulb swap tomorrow and will need to remove the left tire so maybe I can get a clear view with some decent pictures of whats going on in there.
Are you actually more after the parking light bulb colour?
e350
The IR light should not match the OEM headlamp, it should emit invisible IR light (after the conversion, as seen from outside). If you change this bulb to something else, you would loose your night-view performance and the visible colour would not change.
2011 E350
Wow this is confusing. You have Nightvision but you want to disconnect it and you're upset that you can't? Why? Or am I misunderstanding?
Received 3,353 Likes
2012 CLS63
...good to have the information anyway......
e350
I honestly don't know why they would put this light on the car and call it night view. They're two tiny led chips that look yellow once they pass through the projector. The cornering lights are cool(light up when you turn), and they can be interchanged with any H7 bulb. But to add a light in that area of the headlamp that can not be modified just does not make sense to me.
E350 4matic
yeah....I think the led chips are just the parking lights that sit in the same housing which are sorta bluish in color. I have night vision and I can never see the night vision lamps themselves light up like the picture that is posted. Its really cool though how strong those are when in night vision mode.
e350
The manual says it is the IR/Nightview for the bi xenon cars but I have just realized that this part of the headlamp is the parking light. That makes it even ridiculous, I don't even need parking lamps.
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Please post pics of the car with only 1 of the 2 lights on each side on at night. I have a feeling i won't look too good....
