Sponsored by: CARiD
Window Auto Up - Not working
Old Nov 9, 2010 | 10:58 AM
KonradE63's Avatar
2010 E63
My window auto up is not working on only one window. Is this something I can reset, or will I have to take it to the dealer?
Old Nov 9, 2010 | 11:41 AM
Beausoleil's Avatar
E350
In most cars I've experienced you have to run the window to the top and continue to hold the button for a few seconds to reinstate the feature.
Old Nov 9, 2010 | 12:04 PM
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
Try realigning the sensors like Beausoleil suggested. If that doesn't work you need to take it. I had that with my car; the dealer hooked it up to a laptop and fixed it in two minutes.
Old Nov 9, 2010 | 12:57 PM
hyperion667's Avatar
2012 CLS63
I could swear I remember another thread like this one, but I can't recall.....I do remember the solution was a simple one....
Old Nov 9, 2010 | 03:39 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Mine works fine, but I have another problem with the driver side one, every now and then when I push it auto-up, it goes auto-down.
Old Nov 9, 2010 | 03:42 PM
ash_cpe's Avatar
2010 E350
I have the same problem with my driver's side window. It's annoying.
Old Nov 9, 2010 | 03:47 PM
K-A's Avatar
K-A
The same one I have, or O/P?
It's truly annoying. Also, when it goes down due to this "glitch", it doesn't go back up when I immediately press the button, it just has a mind of its own. I imagine it would suck if someone's trying to reach into my car for foul reasons, and I'm trying to jam my window up their arm.... And it goes down.
Old Nov 9, 2010 | 04:20 PM
ash_cpe's Avatar
2010 E350
Exact same one but with driver's side, I don't even like to open the window because of it. Never had the chance to check with dealer about it.
Old Nov 9, 2010 | 05:17 PM
KonradE63's Avatar
2010 E63
PROBLEM SOLVED!
Thanks to those who replied. Here it is:
while the car is on, lower the offending window by pressing down on the switch, stop, then raise the window and keep the switch in the raised position for a few seconds (10 did it for me). This solves the problem.
Konrad
Old Nov 10, 2010 | 09:56 AM
LRM1's Avatar
2021 E450 4matic
Yes, it was my "tip the service guy" thread.
I think the last poster answered it though. go all down and hold the offending windows button up for about 10 seconds. You should hear a very faint "click". The window should work from there.
Old Nov 10, 2010 | 10:51 AM
Diesel Benz's Avatar
Do you mean the window reverses somewhat when you try to close it with "one-touch" and when it reaches the top?
This could be a calibration issue too. If, for some odd reason (or because of a small object or some dirt at the top window frame) the door control unit assumes the window top position is a bit higher than where it actually stops, the door control unit assumes something is left between the window and the door frame and it needs to back up to release the object, like a had (a very small one in this case ).
Because of the safety backup, the window would not wind up immediately. I would assume it would go upwards if you first open the window somewhat.
I think it would be worth trying to calibrate the misbehaving window (just like for those who have lost the one-touch feature completely).
Old Nov 10, 2010 | 04:07 PM
K-A's Avatar
K-A
That's exactly what it does! Sometimes it'll go up for just a second, then roll down, and sometimes it'll just immediately roll down when I press up. And of course, sometimes it'll work properly.
So to calibrate, I just simply have the window at the closed position, then hold the auto-up for 10 seconds?
Old Nov 10, 2010 | 04:29 PM
Roll down the window and keep your finger on the button for 10 seconds after it has been fully rolled down. Then roll up the window and keep you finger on the button for 10 seconds after it has been fully rolled up. This realigns the window sensors. It works great for sunroofs also.
Old Nov 10, 2010 | 04:44 PM
K-A's Avatar
K-A
Thx. Do I use the Auto down/ups when doing it?
Old Nov 10, 2010 | 04:49 PM
LRM1's Avatar
2021 E450 4matic
Hold down the button, then hold it up, all the way down and all the way up.
Old Nov 10, 2010 | 04:57 PM
K-A's Avatar
K-A
I know I gotta hold it. I mean does it only work if I hold it at either the first or second click.
Old Nov 10, 2010 | 07:50 PM
The 2nd click. You have to press and pull the button all the way.
Old Nov 11, 2010 | 10:17 AM
LRM1's Avatar
2021 E450 4matic
<<<- What he said
Old Jun 2, 2012 | 06:05 PM
Petie G's Avatar
2012 E350 Sport P2 AMG Appearance Arctic White
I just got my new E350 yesterday (almost identical to K-A's) and had the exact same problem with the driver's window. Called the dealer, the told me what to do, fixed it immediately. I rolled the window all the way down. Then, when rolling it up, I didn't do the "express/auto" roll up (didn't pull it up until it clicked). Instead, I merely pulled the button up enough to get the window all the way up. Once the window was up, I the pulled harder on the button to make it click, held it for 15 seconds. Then, I had to "cycle" the car off and on. That meant I had to pull the "engine on/engine off" button out of the dash (very easy to get out) and then reinsert it. Problem fixed in less than 30 seconds.
Old Dec 24, 2016 | 02:33 PM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Great thread....pass window was misbehaving and what Petie said fixed it...nice
Old Apr 16, 2017 | 08:57 PM
Keith Cheung's Avatar
ml320 cdi
thanks it worked!!!!!! All the way down all the way up hold it Walla!!!!
Old Sep 18, 2019 | 05:45 AM
olmate's Avatar
GLA45
Thanks guys......saved me taking it back to the d1ckheads
