Sponsored by: CARiD
1st to 2nd gear**** slow
Old Dec 20, 2010 | 08:11 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
anyone had successful remedy to this issue??
the lag between 1st and 2nd is awful...
just curious
Old Dec 20, 2010 | 08:34 PM
GuyFawkes's Avatar
W163 ML430, W212 E550, R129 SL320
Do you mean the you have to rev it up very high before the gear changes? Are you driving in "E" or "S" mode usually? Or are you talking about in Manual mode when you manually flick the paddle?
Old Dec 20, 2010 | 10:29 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Make sure it's in "S" (if you are truly referring to 1st gear).
Also, try resetting the memory on the tranny (forgot the instructions, but they're easy to find), that is usually the biggest culprit with lagging tranny shifts.
Old Dec 20, 2010 | 10:42 PM
RJC's Avatar
RJC
Various
These card stay in first gear longer when cold to help get the cats heated quickly.
Old Dec 20, 2010 | 11:22 PM
piper's Avatar
Sprint Booster...
Old Dec 21, 2010 | 11:33 AM
SprintBooster's Avatar
Former Vendor of MBWorld
C-Class
Originally Posted by piper
Sprint Booster...
+1
Old Dec 21, 2010 | 07:13 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
yes
and
yes
(newbie stuff)
Old Dec 21, 2010 | 07:14 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
not talking about holding gears - talking about lag while shifting between them...
all the other gears engage much more quickly - independent of engine/drivetrain temperatures
wish i could figure this out
Old Dec 21, 2010 | 07:15 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
No - talking about any change of gear from 1-2 anywhere in the powerband..
doesn't matter but i'm almost always in S
and i'm always using the paddles
Old Dec 21, 2010 | 08:35 PM
will4iron's Avatar
2018 GLC 300 W / 2011 E350W, Luxury, P01, leather steering wheel
'S" means Sports and the manual said if you are using "S" mode, there should be delay in changing gears. I believe "S" doesn't design to use paddle shifter but for when you need 'boost' speed to feel sporty driving. Please find it in your owner's manual. With "E" mode, gear changes faster I believe. I have BMW with 'Manual' mode which lets you choose designated gear whenever you need. I think there are total difference between these "S"(MB) and "Manul"(BMW) modes.
Old Dec 21, 2010 | 11:56 PM
RJC's Avatar
RJC
Various
Ok
What is the service dept telling you?
Old Dec 23, 2010 | 04:23 AM
CynCarvin32's Avatar
Mercedes Benz
Just had people in the family get 3 new 2011 E350 and 63's.
Two of the 350's have terrible shifting. The 350's feel as if the factory forgot to adapt the transmission during production. On cold starts the slip between shifts badly and once under way the odd shifts are very harsh and cause a thud in the drive line.
The solution often is simply a re-adaptation of the transmission and takes about 1 hr at the dealership with the tech using the Diag software to re adapt the values for how much pressure each solenoid needs to create in the system to complete a given shift.
Take it in and ask that the do a re-adaptation and check the trans fluid level.
Good Luck
Old Dec 23, 2010 | 09:33 AM
mg-E550's Avatar
2010 E550 4matic, 2008 MDX, 2011 335i Vert
I havent noticed a huge problem 1 to 2nd...although the paddles are slow no matter what gear you are in.
