P2 Headlight Adjustment
adjust up or down by turning left or right...
aim headlamp angle by placing your vehicle on flat ground next to a wall to see if the beam is dipping. then adjust other beam to match height by pulling your car towards a wall on level ground at about 10 feet.
cheers,
chris
I agree that it is important to use the correct tool, adjusting against a wall or another improper method may not provide optimal alignment, the attached link was interesting.
BTW I wasn't aware of the left side is actually/suppose to dip, while the right side appears to be pointed further out, while the brights are adjusted for an even distribution.
http://en.wikipedia.org/wiki/Headlam...nce.2C_and_aim
