Keyless entry and start, interesting read
http://autos.yahoo.com/articles/auto...h-car-thieves/
Isn't it also that the gear will not engage again if you put it on neutral or park when key is not in the car?
If they can mimic the signal from a keyless go they could drive the car away but as shown on "Top Gear" they only drive a few yards and the car stops once it is out of range of it's keyless go Key.
I'm not sure you could start the engine without a valid signal inside the car on an M-B.
Most of us with key less go never actually manually press a button so the only time the radio frequency is used is very briefly when you touch the door handle and again when sitting in the car.
Scarey stuff though it's better than a home invasion which seems the modern way to get a key.
Bill
I meant that we don't press a button on the keys in our pocket like you do without keyless go.
Not sure the engine start button sends out a radio signal anyway.
These scanners have been around for years but they have principally been used to trap the code when you use your key to lock and unlock your car. This is a significant amount of radio energy and I am not sure that it is equivalent to the intensity of radio energy sent out when your hand touches the door handle with keyless go.
The principle method of stealing a modern car in Australia is by burglary for the keys or home invasion as by law all cars less than 25 years old have to be fitted with a Government approved immobiliser and are very hard to steal quickly.
Oh yes they also use a towtruck.
Bill
I will test out distance car will go later today without key in car.
Bill
Bill
For those without keyless go, this would not work. The key fob would not be sending out any signals until pressed and you couldn't start the car because you'd need the actual key/key fob.
http://www.technologyreview.com/computing/27037/?a=f
I scanned this real quick, probably more than we want to know, how they can access the ECU to put malicious code into an auto (for when you have 20 minutes with nothing to do).
http://www.autosec.org/pubs/cars-oakland2010.pdf
Then, we tried it. We used our cell phones and he held my keys next to his phone and I held my phone next to my car... When he clicked the unlock button next to his phone, it unlocked my car. Now, having that said, this was on a '98 Durango, and some technology has changed since then... But it worked at the time.
I understand that they could be able to drive off with the car but I still don’t know the facts surrounding how far they can drive without the key inside.
They can replicate the signal to start the car but once they drive off with the car the two thieves won’t have your keys signal anymore.
The system works by having a series of LF (low frequency 125 kHz) transmitting antennas both inside and outside the vehicle. The external antennas are located in the door handles. When the vehicle is triggered either by pulling the handle or touching the handle an LF signal is transmitted from the antennas to the key. The key becomes activated if it is sufficiently close and it transmits its ID back to the vehicle via RF (Radio frequency >300 MHz) to a receiver located in the vehicle. If the key has the correct ID the PASE module unlocks the vehicle.
Here you go...
