HOLD Feature awesomeness
http://www.nbcwashington.com/news/lo...117852044.html
I wonder if this accident could have been from hill assist. Isn't hill assist holding the car only momentarily (mainly intended for cars with manual gearbox, to allow the driver to change the foot from the brake pedal to the gas pedal). I don't have a place to test what happens if I open the door when hill assist is keeping the car stationary but it sounds odd if the driver would have enough time to go to the rear of the car before hill assist releases. I'm guessing the person inside made a wrong move.
Hill hold - done automagically by the vehicle when stopped on an incline. Brakes are left engaged for a second or two to prevent rolling backwards as the driver's foot goes from the brake pedal to the accelerator.
Sorry guys, i know I didn't read through the ENTIRE manual and have a sight disadvantage as I bought my car over the phone and never met the dealer for the walk through.
Thank god for this forum! :-)
For example: on my 2012 C300 if you have brake hold activated and remove your seatbelt and open the door a red message will appear on the display. If you get ouf of the car and close the door it will actually begin to HONK AT YOU to tell you to get the hell back inside.
I must say that I like "hold" a lot and,for some reason,have often wondered how effective it is when used on a steep hill.Someday maybe I'll try to find out.
Is that what the hold feature does??
to an early comment above, i do know that if i open the drivers door while in Drive, the car would automatically go to Park.
That's basically what it does.On my Bluetec all one needs to do is,when stopped and without taking your foot from the brake pedal,give the pedal a firm push and,voila,"hold" appears on the instrument cluster.
If you're driving a 2002 CLK it might well not have that feature.IMO,that could be why you can't get it to engage.
I tried the single push...but that didn't trigger HOLD to engage....will try it again later.
