Sponsored by: CARiD
Warning - Serious Service Problems
Old Apr 16, 2011 | 12:10 AM
mysticmarine's Avatar
E class
I went to a local high volume dealer for an A Service for my 2010 E350. The oil filter was improperly installed, and the car had to be towed off the highway 20 minutes after leaving the dealer. The crank bearings are scored and the engine has to be rebuilt. What's happened to Mercedes Benz quality?
Old Apr 16, 2011 | 02:08 AM
golfster's Avatar
Titleist
Sounds more like a Benz dealer service quality problem.
Old Apr 16, 2011 | 07:20 AM
hyperion667's Avatar
2012 CLS63
yipes!!! good luck!
Old Apr 16, 2011 | 07:44 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Yeah, obviously a Dealer Service issue. That sucks. Where are you located?
Old Apr 16, 2011 | 11:16 AM
petee1997's Avatar
...24 GLE53
I would not accept a rebuilt engine. I would insist on a brand new crate engine and nothing else. The dealer has insurance to cover faulty repair work.
Old Apr 16, 2011 | 11:49 AM
park423's Avatar
'14 ML350 GONE-'12 GL450/'10 E550/'10 ML350/'09 C300/'07 ML350/'03 E320
Wow, a new engine needed from an improperly installed oil filter? Didn't know that could cause so much damage
Old Apr 16, 2011 | 12:20 PM
BudC's Avatar
2011 E550, 2013 GLK
No way would I accept that. I'd want a new engine or at least a new short block. When the high sulfur fuels were etching BMW V8 cylinder walls, BMW installed new short blocks.
I usually check the work dealers perform before I leave. Obviously, there are things you can't see but I can't count the times I've popped the hood and found something wrong.
Old Apr 16, 2011 | 01:23 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Certainly no fault of Mercedes Benz. The dealer really screwed the pooch. Sorry to hear about this happening. Keep us posted on the dealer's response.
Old Apr 16, 2011 | 09:45 PM
dariusf's Avatar
2023 CLA 250, 2021 GLC43, 2003 CLK320
wow just wow, thats insane. Not sure how the filter looks on the E, we still have a way to go before it needs changing but I changed it and oil on my CLK a couple times and can't imagine how it could be incorrectly installed.
Old Apr 16, 2011 | 11:58 PM
BudC's Avatar
2011 E550, 2013 GLK
I've been thinking the same thing. If it's blocking oil flow there should be a bypass and/or some kind of notice there is a problem.
If the o-ring on the cap was installed wrong, it could leak oil. I don't see how the other o-rings could cause this kind of problem.
Old Apr 17, 2011 | 09:50 PM
Ctrl+alt+Elite's Avatar
2010 W212, 1985 C10
I agree, mostly like the mechanic was focused on something else.
Sucks to think we put our cars in the hands of someone else who may or may not feel like being at work that day
Old Apr 18, 2011 | 12:57 AM
ImInPA's Avatar
Not a comforting thought. When it really gets you down, just remember that surgeons have those same days.
Old Apr 18, 2011 | 03:43 AM
Racing Dad's Avatar
e63 2010 W212
Wow, talk about a major screw up!
what did the dealer say so far? I'm curious what they have to say.
Old Apr 18, 2011 | 11:26 AM
ash_cpe's Avatar
2010 E350
Sorry to hear that. I had some issues with dealers my self. I think we need a better dealer rating, QC and follow up after dealer's visit. My other car is an Acura, and never had any issues with their dealers what so ever, and they are so eager to acknowledge and fix any issues. Good luck!
Old Apr 25, 2011 | 07:11 AM
urceyes's Avatar
2010 E350 sport sedan
That's unbelievable!! Wanna hows the dealer reply on that!!!!
If I were u I would definitely ask for a new engine or a new car(maybe.....)
Old Apr 25, 2011 | 09:20 AM
ttoE550's Avatar
2015 GL450
I've had this happen 3 times in the last 10 years. First time was in my Porsche 911 and left a lake of oil on my garage floor. Second time was also in the 911 and left a lake of oil on the parking lot at work. Third time was in my Subaru WRX and left a lake of oil at a nearby Barnes and Noble. Jeez, I'm as bad as BP!
Old Apr 25, 2011 | 02:51 PM
urceyes's Avatar
WTF?
Old Apr 25, 2011 | 04:03 PM
ttoE550's Avatar
2015 GL450
Originally Posted by urceyes
WTF?
Yeah, weird huh? Each by a different dealer too! I'm real nervous the first few days after an oil change...
Old Apr 25, 2011 | 04:11 PM
urceyes's Avatar
actually how could that happen? they freaking charge hundred hundred bucks for services (i guess Porsche must be a lot higher~!!) and end up fxxx up the services..... did u ask for compensation?
Old Apr 25, 2011 | 04:27 PM
ttoE550's Avatar
2015 GL450
The first was caused by a ring damaged when the tech put on the filter. Second the filter was cross-threaded. Third the tech got distracted or something and didn't fully tighten the drain plug. In each case, I got my entire service bill refunded (plus all towing/transportation charges paid, of course). You're right -- for the Porsche, that was a few hundred bucks.
Old Apr 25, 2011 | 05:10 PM
RJC's Avatar
RJC
Various
Dealership should step up big time, between them and MB you should either get one hell of a deal on a left over 11, or at the very least a new engine.
Old Apr 25, 2011 | 05:21 PM
park423's Avatar
So I had a Chevy Surburban about 10 years ago, got rear-ended and fixed at body shop affliated with my local dealer. I drove around all day, finally, while going about 30 mph my rear left tire went flying off my car and landed about 50 feet away in a empty parking lot, my brake calipers went through a wood sign and broke it in half, other parts all over and my rotors dug a trail into the asphalt for about 20 feet. The body shop apparently forgot to tighten the bolts. They could have killed me or someone else. Extremely lucky no one got hurt.
Old Apr 26, 2011 | 07:50 AM
2012 CLS63
I hope they replaced all the parts on your truck no charge.....
Old Apr 26, 2011 | 09:12 AM
golfster's Avatar
Titleist
I've now seen a few threads with similar characteristics. The OP, typically with very low thread count, starts the thread with a rant about a problem - then, no further posts or updates. The other members contribute condolences, opinions, advice, etc., but we never hear the outcome.
I sometimes think these threads are started by a member with pseudo-screen names just to keep the forum active. To the OP, if real, I hope the dealer resolved their oversight and are making the inconvenience worthwhile for you. Please let us know how it goes.
If not real, at least it advanced the discussion from the coolness of the brake/hold feature!
Old Apr 26, 2011 | 01:31 PM
park423's Avatar
Yes and rental but they were also very lucky no one got hurt, could have been a terrible situation.
