Sponsored by: CARiD
Need help with lowering
Old Sep 27, 2011 | 04:28 PM
fallen's Avatar
2014 E550, 2015 E63S, 2017 G63 - RIP
Would like to lower my 2011 E550 via links; looking for a reputable shop in Los Angeles area to do the job.
Your help is highly appreciated!
-fallen
Old Sep 27, 2011 | 08:49 PM
hansolo1019's Avatar
2011 E350
What kind of suspension you planning on running?
2011 E350
I am getting mine done at my friend's shop, so I will let you know.
Old Sep 27, 2011 | 11:18 PM
fallen's Avatar
E350 runs on springs and E550 has an air suspension at all 4 corners thus different methods of lowering...
Old Sep 28, 2011 | 06:33 PM
fallen's Avatar
OK, if no one can recommend a shop in Southern Cali maybe someone can share steps/instructions on how to do it yourself?
Old Sep 28, 2011 | 06:35 PM
shellx's Avatar
2008 CLK63 Black Series
Post up in the w212 AMG section; someone will definitely know!
Old Sep 29, 2011 | 06:29 PM
ghh429's Avatar
MB W212; NISSAN R35; BMW E60
The proper way to lower this vehicle on air suspension is actually by modifying the target ride height set by the factory computer.
H&R has a kit ($2100 ) that plugs directly into the factory ECU. Personally I think this is ridiculous. Those with access to the ECU can also change the settings - the dealer can do it if you ask real nicely or you can go aftermarket.
Try SP Engineering 626-333-5398 in Industry - they can most likely do it for you as they have access to the computer.
Good luck!
BTW I lowered my E55 this way, but just ended up replacing 2 bumpers on my driveway - something to think about
Old Sep 29, 2011 | 06:35 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Harbor Motorsports in Westminster.
Ask for John.
They do all the work on my cars and work for a number of forum members here.
Might be a little bit of a distance from you but I wouldnt go anywhere else.
Old Sep 29, 2011 | 07:52 PM
shaytun's Avatar
2010 E550 4MATIC
I've used the Renntech lowering module (not links obviously) without issues for the past 4-5mo. The ride hide is customizable.
Old Sep 30, 2011 | 07:30 AM
fromthebeginnin's Avatar
Black W212 E550
I live in NorCal (so I can't recommend anyone for you)and have used links because of the stories I have heard about failures from one of the big name electronic lower kits , once I set it I never had a desire to change. I know the older E classes can be lowered with Diagnostics but I haven't heard of anyone doing it on W212 E550. Would be interested in an info or experience anyone has.
