bluetooth meta data
just an FYI for all.
Regards,
Don
We have the same car and I can't!
Questions:
1. Did you have to set anything in the Engineering Menu or any other menu?
2. Are you untethered or are you connected to the IPOD cable in the glovebox?
3. What IPhone iOS version?
Thanks,
Don
As for the questions:
1. I didn't go into the Eng menu at all. It just worked.
2. Yes, untethered. Streaming straight from BT. Works for MOG, Pandora, iPhone music, etc.
3. I'm now on version 5.1 but it has worked as long as I can recall. My daughter's ipod touch should still be on the previous version; I'll test it out with that and let you know it the version matters. Hubby hasn't upgraded his iPhone either so I'll try both.
Regards,
Don
Seeing metadata requires AVRCP 1.3 in the COMAND system. The 2011 COMAND supports it.
The iPhone started supporting AVRCP 1.3 in iOS 4.something.
When I first paired my phone, I was using an early iOS that didn't support 1.3.
Once the phone is paired, apparently, it never shares its protocol support again with COMAND, even if it has changed. COMAND simply remembers the phone's remote control protocol level from when it was first paired.
Since I paired the phone before it supported 1.3, no matter how many times I updated the iOS, COMAND never knew it supported 1.3.
The trick was to de-authorize the phone from COMAND and go through the pairing process again from scratch.
So, now I am a happy camper and will be able to get rid of SIRIUS, replacing it with Pandora.
Hope this helps someone else.
Regards,
Don
Regards,
Don
Pandora is great. I also like Rhapsody and (less often) ooTunes.
Thanks for posting your suggestion. Wish it had worked for me too.
Regards,
Don
I'm okay with it. If I am desperate to know who/what is playing, it's easy to push the home button on the phone. Now if we could only manipulate the phone audio from COMAND (beyond last-song, next-song)...
It's great just to have an alternative to overpriced satellite radio, though, isn't it?
Pandora via the iPhone works great around town and I use a program called tunebite to record hours of Pandora to cd's to use when I'm traveling in those areas where cell phone coverage is spotty. (I live in the desert southwest so they're commone here.) I also believe the quality of Pandora (using the pay version, Pandora One) is better than Sirius.
Regards,
Don
Even the free Pandora has better sound quality than Sirius! Plus, I can dislike songs and never hear them again. I've got 4 or 5 channels perfectly set for my various moods (instrumental rock guitar with no Steve Vai, heavy electric bass jazz, etc.). It's great!
And, thanks to you, I now know who's playing.
