Sponsored by: CARiD
Airmatic Issue
Old Dec 17, 2011 | 09:08 PM
Tai230K's Avatar
2011 E550 Sedan
Airmatic Issue
The airmatic suspension has been giving me a bit of trouble lately. Every morning I wake up to a very low driver side rear. The car has about 7000 miles on it so I just brought in the car to the dealer as they diagnosed the problem to be a leaky airmatic valve. Well they fixed it and the following morning same problem... I'm thinking about bringing it in again. What do you guys think? Airmatic strut or sensor?
Pictures below:
Right after getting out of car
Less than 12 hours later:
Old Dec 17, 2011 | 10:04 PM
Tjdehya's Avatar
2023 AMG EQS
If you have no issue when driving then I doubt that its a sensor or strut problem.
The car continually adjusts the suspension when parked for a limited time (I dont know how long)
If you have time read a book in your garage and listen to see if the pump is continually running after parking, if so then you have a leak somewhere.
If it lowers without the pump trying to adjust then you maybe right about the sensor or maybe the Airmatic processor under the front passenger side floor.
Old Dec 17, 2011 | 10:23 PM
wally AMG's Avatar
MB
I will say strut problem.
Old Dec 17, 2011 | 10:40 PM
e550 87ss's Avatar
E63, E90
AMG over the weekend was also low after being parked for a few days, e550 at the bottom of the link: https://mbworld.org/forums/w212-amg/...-warranty.html
Starting to think this is normal... unless it is sitting on the tires or pump constantly running...
Old Dec 17, 2011 | 10:54 PM
Brando253's Avatar
2016 E63s, 2014 CLS, 2013 E550 (retired)
I had the same issue on my 2011 E550, both rear struts replaced at 6500 miles.
Old Dec 18, 2011 | 08:14 AM
hyperion667's Avatar
2012 CLS63
haha 87!!! i was just going to mention that
thanx main!
Old Dec 18, 2011 | 01:01 PM
Yosheego's Avatar
2011 E550
I had the same issues with the right rear. I had to bring it in twice before they said it was a leaky valve. The first time, my struts/bags was replaced. I just hope on the long run, we all don't run into these..."starting to be common" problems.
Old Dec 20, 2011 | 06:29 PM
ngerstman's Avatar
2016 Audi S8 Plus/ 2011 Mercedes e550 4Matic//Gone:1985 500SEL/2000 e320 4Matic/ 2001 e55 Kleeman
Pictures below:
Attachment 224455
Attachment 224454
It never occurred to me that there might be a problem. I have noticed that my two rear shocks are way lower every morning than when I park it the night before. As soon as I start the car in the morning, the compressor goes on and the rear shocks rise to normal level. Is this not normal? Should the shocks not be losing pressure over night? Regards. Ned.
Old Dec 20, 2011 | 08:12 PM
2012 CLS63
I'm far from expertise Ned, but I don't think it should sink over night you know?
let us know, seems more are seeing this happen
Old Dec 20, 2011 | 08:30 PM
golfster's Avatar
Titleist
When I was getting service A performed, a flatbed was unloading an E 63 (211) with Airmatic failure. My SA said that was only one issue and pointed to the sheared and twisted front fenders. It seems that when the suspension dropped, the driver panicked and turned abuptly to exit the road and the wheels created the damage in the turn. I don't know if the car had been lowered prior to the failure or if it was riding on a standard airmatic suspension, but it was alarming to see the damage.
Old Dec 20, 2011 | 08:38 PM
fingroupb's Avatar
2011 E550, 2018 Land Cruiser, 1966 Vette
Just got mine out of the dealer for the same issue: rear was slammed, not overnight but if it sat for 48-72 hours. Part numbers 212-320-03-25 and 212-320-06-25 ("Air Spring") were replaced.
Guess it is normal
edit: 3000 miles on my car
Old Dec 20, 2011 | 08:52 PM
ngerstman's Avatar
Guess it is normal
Sorry, I'm not fully getting what you are saying. You had the shocks replaced and they still deflate after a few days. Or did it stop doing that after the repair. Thanks. Ned.
Old Dec 20, 2011 | 08:56 PM
ngerstman's Avatar
Do your airmatic shocks deflate overnight like mine? My rear shocks rise by 3-4 inches every morning when I start the car. Thanks. Ned.
Old Dec 20, 2011 | 09:06 PM
fingroupb's Avatar
I just got home with the car about two hours ago; so far, it looks good
Prior to taking it in, it took 48-72 hours for it to lower itself, at least to the point that I noticed. This pic is after 72 hours and is what prompted me to take it in:
Old Dec 20, 2011 | 09:35 PM
Big50's Avatar
2010 E350
I bet this is why MB is taking the airmatic out of the 2012 550's.
Old Dec 20, 2011 | 10:00 PM
ngerstman's Avatar
Let me know if the issue goes away. Did the techs say there was an issue and that the air shocks shouldn't lose pressure? Thanks. Ned.
Old Dec 20, 2011 | 10:11 PM
fingroupb's Avatar
Ned, if your car is settling overnight, it's an issue. It's a warranty repair. I think the spec is more than 20mm -- in my case it was deflating 2.5 inches in the rear.
The car should be sitting over the holidays so I hopefully I will find that it's resolved. Yosheego up above posted that his "airbags" (the term used by my SA) were replaced and that did not resolve it. So we'll see.
Old Dec 21, 2011 | 08:03 AM
2012 CLS63
Old Jun 17, 2015 | 09:21 AM
raygarner's Avatar
S550
W221 Airmatic Promblems
So all I drive 2008 S550 had the same problems there were 2 issues really inexpensive fixes
1. the fuse had blown causing the car to drop
2. there was a leak on the actual hose around the airmatic pump
Suggestion: change the fuse (40amp) if you hear the pump come on and the car falls later then their is a leak at the pump
