Engineering Mode
Old 12-10-2013, 05:45 PM
gusecu's Avatar
2013 C250 - Lunar Blue
Originally Posted by TwinCam
Rear view camera is in the basic settings. I am not in the car right now so I can't give you the exact location. If you don't see it, I will give further instructions. I found it while looking for the map screen orientation...I wanted the car always displayed pointing to the top of the screen, not to North.
TwinCam,
Does your engineering menu look like the one BenzV12 posted at the top of this thread? That is what mine looks like, and I do not know where to go to find the camera. I have searched through it, but have not found it. Any help would be GREATLY appreciated!
Thanks,
Gus
Old 12-10-2013, 05:55 PM
TwinCam's Avatar
2021 Cirrus Silver S580 AMG, 2020 Polar White GLE350
Start with your regular command screen not engineering mode. Go to the top and click on system. When that screen comes up, click on settings. The next screen shows a list of items, click on "rear view camera". You will see "activation by R gear". Click to put a check in the box and you are all set!
Old 12-10-2013, 05:58 PM
gusecu's Avatar
Unfortunately, that does not come up in my "system" section.
Old 12-10-2013, 06:08 PM
TwinCam's Avatar
I have a 2014 E550 and one of the settings on the main command page that has audio, navigation, etc. is "system". Clicking on that takes me to a page that has "settings" in the lower right. Sorry this doesn't work on your model. Check you owners manual and see if they have a section on the rear view camera. If not, look in the command manual. Good luck!
Old 12-10-2013, 06:37 PM
TwinCam's Avatar
I went to mbusa.com and found the Comand Manual for the 2013 C cars in the "Owners" section. It shows the rear view camera on and off is located in "settings" under the "system" section. Make sure you start with the main command page. Do not use "engineering mode". If you have trouble getting out of engineering mode, press the audio button to bring up the main screen. At the top right should be the "SYSTEM" box. Clicking on that should bring up a screen with "SETTINGS" in the lower right. Click on that box and the rear view camera setting will be shown.
Old 12-11-2013, 09:43 AM
gusecu's Avatar
Thanks Twincam, but my system / settings menu does not have it. I am assuming it is because the car did not come with a back up camera, so there is not an option in the settings menu (accessed from the command / system page).
That is why I think I have to turn something on in the engineering menu to give me that option in the settings menu.
While in the engineering menu, I did find this menu (see attached picture). I went to the "ExtPlayer" section and found this. Does anyone know what a UCI device is?
Old 12-11-2013, 12:19 PM
  #32
TwinCam's Avatar
Guseco, your right, without a factory installed rear camera there is no need to have a rear camera section under settings. Personally, I don't know why anyone would turn off the camera, anyway. Hope you find a solution!
Old 12-11-2013, 01:33 PM
  #33
gusecu's Avatar
Twincam, Thanks for taking the time to try and help! Much appreciated!
Old 12-12-2013, 03:09 PM
  #34
Arrie's Avatar
In my car the engineering menu has a place where you can turn the rear view camera to "Not Installed". I have not tried this setting but I would guess it will remove the camera ON/OFF selection from the System-menu.
This being in the engineering menu would suggest to me that this selection is used for "Not Installed" option for cars that do not have the camera.
It also has three other options: SRVC, DRVM and DRVM-PSC. I guess these are different camera types. Mine is set to SRVC.
This selection is at location:
7 HW Settings
7.7 HU Parameter (3/6)
(20) Rear view camera
Under the (20) Rear view camera are those 4 selection options
Old 02-21-2014, 10:20 AM
  #35
ozel6161's Avatar
E 250
Originally Posted by ozel6161
Today I went to first service my car(207) and ask the dialer this BT audio feature set2 make ON.And they will wright the Mb DATA service.İf they can make it ON i will wright here at the end.İ think it will take nearly 10 days.
MY Dealer said to me
At the and yesterday Mercedes trip write to my dealer ''we can't do nothing,we can't change anything''
and they will change te web page data about show who works the audio 20 BT Streaming
Old 11-30-2014, 08:00 AM
  #36
shanaka_r's Avatar
w212 e250 2010
Originally Posted by Joschelito
Thanks for the info.
I could enter to the Engineering menu in my E class Coupe with Audio 20, but when I activate Bluetooth external Features and reboot the system, it stays in off again.
is there any way to reset the system and add AutioStreaming??
When I tried the eng menu it worked. But after reset I had to de-authorise my iPhone and re-authorise and then it was taken up as a bluetooth audio device and now it plays off my music library without any issue.
Old 11-30-2014, 10:04 AM
  #37
wanderfalke's Avatar
e550
I can't get the links for the site to open.
Old 11-28-2016, 07:12 PM
  #38
Rovel's Avatar
2007 E63 Amg
I hope this chain is still alive.
I need your help, guys! With the help of this chain, I was able to turn on the browser in my 2013 E550. However, when I went to the Settings, I couldn't find USA in the list of countries (as my car is a canadian car). Therefore I am not able to use my iPhone as a modem and access the internet.
Would you advise on how to add US ATT iPhone to the list?
When adding a new provider manually, it asks for Provider, Tel Number, Access Point etc. What should I enter in those fields?
Thanks in advance.
Old 11-29-2016, 12:36 AM
  #39
belarus27's Avatar
2010 e550 p2
Thanks in advance.
https://www.google.com/search?q=at%26t+apn+settings&oq=att+apn&aqs=chrome .2.69i57j0l3.3926j0j4&client=ms-android-verizon&sourceid=chrome-mobile&ie=UTF-8
Old 11-29-2016, 08:14 AM
  #40
Rovel's Avatar
2007 E63 Amg
Thanks Belarus27 for reply. I was able to find what you sent, but couldn't figure out what to type where. I am attaching a photo of what the screen in comand looks like. Please let me know what should be entered in each of the fields.
Also do you know if iPhone 6 with the latest ios will work?
Spasibo
Old 11-29-2016, 08:15 AM
  #41
Rovel's Avatar
2007 E63 Amg
Spasibo
Old 11-29-2016, 10:18 AM
  #42
belarus27's Avatar
2010 e550 p2
i never tried it so not sure , how the internet part would work lol maybe someone else would be able to chime in
and as far as iphone 6 i read a few days ago that new update dont work right , and there are issues with connecting and no stable connection.
"cant remember which thread it was"
edit:and i think it was on 10-12 models only not sure.
haha you welcome
and a video maybe that could help
Old 11-29-2016, 10:40 AM
  #43
Rovel's Avatar
2007 E63 Amg
haha you welcome
https://www.youtube.com/watch?v=DJeFOZPithA
I hope someone else can help here. In the video, the guy chose automatic from the list and was able to connect. I cannot choose USA from the list of countries (it is not there). Otherwise I would have chosen USA, then ATT from the list and click connect.
My car is 2013 with an updated interface, I think, and I am hoping in this year car the internet with iPhone should be supported.
Anybody can help?
Thanks.
Old 11-29-2016, 06:30 PM
  #44
flipstah's Avatar
2010 E550 4Matic
Thanks for this! Just activated the Bluetooth audio so I'll test it out today.
I wonder if I can get COMAND Online to work on an iPhone...
Old 07-09-2018, 09:26 PM
  #45
iconoclast's Avatar
Audi BMW Ferrari MB & RR
Anyone on here know the sequence for Engineering Mode for NTG5S1?
Neither that I am aware of have worked.
Old 10-13-2018, 05:10 PM
  #46
Yamel Marquez's Avatar
gle350
Engineering mode I try 1# and is no working can you help
I try to use the engineering but the manue don’t come up
Old 10-15-2018, 08:23 AM
  #47
iconoclast's Avatar
probably disabled and needs to be enabled through xentry.
Old 10-24-2018, 04:36 PM
  #48
Jdztvr's Avatar
2010 E550 4matic
Having the same issue, can’t get into engineering mode with the “hang up, 1, #” method. What is xentry?
sorry, I’m new to the MB world.
Old 10-02-2019, 12:43 PM
  #49
bachree's Avatar
2010 e350 Luxury p2
Where exactly is the setting about phone volume? Pictures are deleted
Originally Posted by BenzV12
I am a member of one of the most helpful sites and came across something called ENGINEERING MODE and digged up what it was about .I have to say that I am puzzled because I learnt that you could change some sueful features thru your COMAND .
So, I will send you some images therefore you can easily see how to enter this mode and use it
To enter this mode, you need to do these simultaneously :
red phone button , 1 ,# .Press these at the same time and hold them 10 secs . You can gain access bluetooth, phone ,TA,radio functions and settings .
The image below shows phone settings :
This image below is about system settings :
Now, this is about phone volume level , if you think your phone volume is too low , you may need to use these settings :
This image below shows earphone settings , you can change them if you like .
This is about equalizer :
This image below is about listening to music thru your phone's bluetooth connection :
Old 10-10-2019, 05:29 AM
  #50
azzurri1899's Avatar
S450
Hi Guys,
How to get "Engineering Mode " on S class 2018 face left ?
Quick Reply: Engineering Mode
