Strange happening, anyone else?
Anyone seen this before in their W212? This is the first glitch I have seen in over 2 years of driving this W212.
There are some on this board who think the car should stop running when the key cannot be detected by the car. This suggests it's a good thing it doesn't!
Regards,
Don
I had this happen a few times with my 2011 E350 and it has happened on my current 2010 E550 a couple of times. I keep my key in my left front pocket and I think it just sometimes doesn't see the key. When I move a little bit or take the key out of the pocket it sees it no problem.
If it is a low battery it will give you a message to replace the battery. This has also happened to me and I did replace the battery. No message after that.
At this point I am attributing this to either the Cell phone end call being pressed on my wife's phone or some strange interference. Been using the car every day this week since it happened and have not seen it happen again.
One of the reasons the Keyless Go battery discharges so much faster is because of the fact that it isn't powered by the car while you're driving. When you insert the actual key into the ignition module an inductance coil provides all power to the key (which is why your key will start your car even without a battery installed). The coil may even apply a small charging current to the lithium battery in the key while driving in order to extend its life further (haven't read that in the documentation though, just an assumption). This is the same technology your electric toothbrush takes advantage of in order to recharge.
