Sponsored by: CARiD
Question on tire pressure
Old Apr 29, 2012 | 04:52 PM
MB-JIM's Avatar
06 C 350 2014 GLK350
On my 2012 Luxury model, the normal pressures shown on the gas filler door are 35/36. My friend, with a 2011 E550, and the same Michelin Tires said his shows 30/35. With his heavier engine, I would think that his front recommended pressures would be higher than mine.
I wonder if for 2012 they might have raised the recommended pressures to get a slight improvement in mpg?
I would like to know, if someone has a 2011 E350 Luxury, what is shown for the normal tire pressures?
Old Apr 29, 2012 | 06:10 PM
listerone's Avatar
2018 BMW 540d
Mine's kinda funny,the door jamb reads 35/39,the fuel filler door reads "standard load 35/36,full load 35/39".However,it's a diesel with run flats,so that might make for different recommendations.
Old May 1, 2012 | 09:14 AM
mikemargolis's Avatar
'11 E350BTC P2 Leather
I have mine (run flats) filled to the suggested 35/36 when cold.
I notice they go to about 39/40 when they're warmed up and cruising on the highway, which I do quite a bit.
Is that OK, or should I lower them a little?
