Sponsored by: CARiD
"HOLD" function...NOT!!!
Old May 20, 2012 | 07:59 PM
hofb99's Avatar
2012 E350W4
Okay, as my sig denotes, I own a 2012 E350 4Matic. Never gave any thought to this, but I can't seem to get the simple "HOLD" function to work when pressing the brake @ a stop (hasn't worked once since driving it off the sales lot). I guess in all the excitement of purchasing this beautiful vehicle, I simply dismissed it as "...maybe it's not a feature w/ the 2012 MY...", but after reviewing the owner's manual (and following the instructions to a tee) and calling mbrace while in the car (again w/ no success), it just doesn't work. So has anyone else out there w/ a 2012 (or possibly other MYs) experience any problems w/ the "HOLD" brake feature? Any input/help would be greatly appreciated!
Old May 20, 2012 | 08:06 PM
dfordham's Avatar
2014 E350, 2012 SL550
Once you are at a complete stop, press the brake pedal hard, not necessarily fast, just hard. A "HOLD" indicator will come on in the instrument cluster.
It requires a little technique, but if this doesn't work take it in for repair. It's a nice feature.
Regards,
Don
Old May 20, 2012 | 10:13 PM
listerone's Avatar
2018 BMW 540d
Yup,when you're stopped press the brake pedal firmly and it will engage.Works for me every time...no problem.
Old May 20, 2012 | 10:20 PM
BM2BZ's Avatar
w212 E550
like what don said, no need fast. but in my experience, no need that hard neither. at a complete stop, press the brake pedal as usual then press in a little further. if you still have problems after numerous times, you might want to take it to the dealer. could be some problems.
Old May 21, 2012 | 02:52 AM
instantfob's Avatar
'19 MBZ E450 Wagon, '19 BMW 530e
"HOLD" can be triggered on flat / downhill situation.
If you are stopped at an incline .. your car automatically engages hill-hold.
Old May 21, 2012 | 03:36 AM
axhoaxho's Avatar
I have a 2012 E350. I use the Hold function all the time, and I enjoy this function very much.
To engage it, without better words...
- Let's say my car is at a full stop on a flat road, and my right foot is on the brake pedal.
- The brake pedal should be at, just as an example here, about 3/10 of its travel.
- Without releasing my right foot; I then 'jab' my right foot down with a quick motion to depress the brake pedal further, from its 3/10 to 8/10.
- At this moment, the hold function should be engaged automatically, and the word 'Hold' should be displayed on the dash.
- Then, if I release my foot from the brake pedal, the car should be in Hold mode.
Try to find a clear and safe flat road to practice it a little. It might take a few practices to get it. Once we get it, it would become natural.
Hope it helps,
With best regards,
Old May 21, 2012 | 07:11 AM
leapingpoint's Avatar
E-class
Hold function has been around for some years, my 2004 W211 has it and still works. If u can't get it to work, it is better take it to a dealer... either have them show u or get it fixed. It's a bit like riding bicycles, hard to explain via words, but yeah, what people have said above.
Old May 21, 2012 | 09:57 AM
Arrie's Avatar
Be careful with hill hold. It only holds about a second and a half after you release the brake.
Old May 21, 2012 | 11:04 AM
BenzMan369's Avatar
2012 E350 Coupe
An important distinction is being made here.
It's true that the hill hold feature will engage automatically with the driver doing nothing, but unless you deliberately set it by firmly depressing the brake and causing the HOLD light in the display to come on, when you remove your foot from the brake the function will disengage after a very short period designed to allow you to get your foot from the brake to the accelerator without coasting backwards.
With the hold function deliberately actuated by the driver, the car will remain stationary indefinitely, until you depress the accelerator.
MB refers to these two operations separately. The short, automatically engaged hold function is called "Hill Start Assist," while the deliberately driver-actuated permanent hold function is in fact called "Hold Function."
Old May 21, 2012 | 11:11 AM
ttoE550's Avatar
2015 GL450
Another poster, I think K-A, says that his car automatically went into P after a longish time of having the hold function activated.
Old May 21, 2012 | 11:49 AM
BenzMan369's Avatar
2012 E350 Coupe
Thanks for the info.
Geez, by that time the guy behind you on the hill may have worn his battery down blowing the horn - or may have shot you.
Old May 21, 2012 | 11:51 AM
ttoE550's Avatar
2015 GL450
I use the hold function at stoplights when I want a very quick getaway. It is awesome, and the car seems to start in 1st even without the Sport mode. It would be embarrassing though if the car went into park and I was sitting there revving my engine!
Old May 21, 2012 | 01:09 PM
chrisvr6's Avatar
lexus gx470
Quick jab on brake while barely holding brake enough to hold car.
Old May 21, 2012 | 03:17 PM
hyperion667's Avatar
2012 CLS63
+1 on the quick jab.......and it's an awesome feature too; use it often
Old May 21, 2012 | 05:46 PM
mnje350's Avatar
2010 E350, 2015 S550
Off topic but I can't help but say all of the pix that Hype has on his posts are awesome.
Old May 21, 2012 | 06:56 PM
BM2BZ's Avatar
w212 E550
this is the thread for all his crazy nice pics: https://mbworld.org/forums/e-class-w...212-board.html
Old May 21, 2012 | 08:11 PM
2012 CLS63
many thanx you guys!!!
always up for picture viewing
Old May 21, 2012 | 11:00 PM
troymir350's Avatar
2019 AMG GLE 63S
Had no idea this existed. Have had 5 MBs and I guess this is a reason to read!
Tried it tonight and worked as noted. Makes we want to find a traffic jam.
Old May 22, 2012 | 11:34 PM
hofb99's Avatar
2012 E350W4
It worked!!! Thanks for EVERYONE'S input...it really helped! Especially axhoaxho, chrisvr6, and hyperion667 for the "quick jab" reference... So my last ditch effort before hauling the E to the dealer, I thought to myself, "hmm...didn't really try the quick jab approach"; was really only pressing "long and hard". So, just went out and "jabbed" just a bit, keeping axhoaxho's "3/10 to 8/10" in mind, and got it to work and now I get it everytime! REALLY nifty feature! The advantages of forum membership! Who needs mbrace??? What can I say, you guys are AWESOME!!! Wifey's gonna love this! (did I get enough of them in?!! lol)
EDIT: was thinking M-B should include this as one of their training videos on their site! But, then again, seems I'm the only goofball that wasn't able to figure it out... --thanks again fellas!
Old May 23, 2012 | 03:41 AM
axhoaxho's Avatar
Good to hear! Enjoy your car
Old May 23, 2012 | 04:54 AM
BM2BZ's Avatar
w212 E550
it is on their site but you were probably too excited about your new ride and didn't pay close attention. here is the video:
http://www.mbusa.com/mercedes/owners...007c184335RCRD
Old May 23, 2012 | 05:09 AM
BenzV12's Avatar
W212 FL
I apreciate your feedback , kudos to you . I think BM2BZ is right with his statement you should be too excited about your new ride lol
Manual also states that , I am also learning some hidden cool features of this car as I drive it
Old May 23, 2012 | 05:14 AM
BM2BZ's Avatar
w212 E550
hidden features ? please tell me where is the eject seat button .
Old May 23, 2012 | 02:47 PM
BenzV12's Avatar
W212 FL
LOL, this sounds like JB car and I think you need to drive Aston to get one of these buttons
Old May 23, 2012 | 03:49 PM
2012 CLS63
haha, the DB5 right? from Goldfinger
