collision prevention assist
PreSafe recognized the rapid approach to the car in front of me and was on my brakes before I could get my foot to the brake pedal. It gave me the classic Mercedes two-beeps as it was doing it, and tightened my seat belt.
Everything turned out fine. I didn't really need the PreSafe, but had I been daydreaming, it really would have helped prevent a collisiion or reduce the seriousness of one.
The front seat belts are pre-tensioned.
It adjusts the front-passenger seat if it is in
an unfavorable position.
The air pressure in the side bolsters of the
seat cushion and seat backrest of the front
multicontour seats is increased.
If the vehicle skids, the panorama
roof with power tilt/sliding panel (or, presumably, the standard
power operated roof if so equipped) and the
front side windows are closed so that only
a small gap remains.
If the hazardous situation passes without
resulting in an accident, PRE-SAFE slackens
the belt pretensioning. The air pressure in the
side bolsters on the multicontour seat is
reduced again. All settings made by PRESAFE
can then be reversed.
Amazing stuff.
Bigh123 has it right, MB seems to delight in creating multiple intricate systems names resulting in consumer confusion. All with the best of intentions, of course.
"Pre-Safe" is a part of the vehicle's Occupant Safety Systems. It does nothing to apply automatic braking in emergencies.
"Pre-Safe Brake" is a separate function and is part of the vehicle's Driving Safety Systems. It does indeed provide for automatic braking to slow the car down and give you time to fully stop the car or take other evasive action. It should also give you both visual and audible warning, as you probably already have experienced.
"Pre-Safe Brake" is only available on cars equipped with the Distronic Plus Driving Safety System, which I assume your car has.
It's all spelled out in the four billion page Owner's Manual.
Don't mean to argue or quibble over terms, but, since vehicles may have Pre-Safe, but not be equipped with the extra-cost D+ option and therefore don't have Pre-Safe Brake, IMO it's important that others reading the thread whose vehicles are not equipped with D+ (like me, e.g.) don't expect their vehicles to automatically brake in collision-imminent situations merely because they have Pre-Safe.
Too bad this is not in more E class vehicles. Distronic and the radar sensor is an extremely rare option. It is really a feature that can save your life. This is even very rare on most S class vehicles out there. I always envy someone when I see the little glass cover on their grill...
I should have commented to LiveOak how valuable and reassuring the posting of his experience with D+/Pre-Safe Brake is, especially to those of us who don't have it. It's an option I will now definitely consider on my next car.
So LiveOak, thanks for your story. No matter what you call the system, it worked!
Pre-safe brake in my 2010 E550 works as follows:
If the D+ radar sees a danger of collision it gives a double beeb warning 1.5 seconds before the collision would actually happen. If I touch the brake pedal after the warning the car applies 100% braking power.
If I don't touch the brake pedal the car will automatically apply 40% of braking power 0.5 seconds before the collision. This means that the collision will happen but with less impact.
Above functions have nothing to do with cruise control being on or off. This is enabled at all times as long as you have the pre-safe brake enabled in the cluster selections.
There is a very good video in the utube explaining this.
An A+ from me too. I have experienced the double beeb twice and the car does a real good job applying the brakes when I step on the pedal.
I obviously remembered the times wrong. The double beeb comes 2.5 seconds before the collision and if I don't touch the brake pedal the 40% automatic braking starts 1.5 seconds before the impact.
I could have sworn that I read somewhere it is 100% braking power when the pedal is touched after the double beeb but the wideo in the below link says it adjusts the braking power depending how much time it has left to stop the car. For me it sure felt 100% braking during both times I experienced it.
It has some other stuff at the beginning but the later part is the Pre-Safe stuff.
I'm really surprised that from the W211 to W212 the stopping distance did not change much and is around 125 feet. About the same as the huge Volvo XC90 SUV...
Still, there is something that bugs my mind so it didn't fully stop the car in the last part of the 1st video ,actually MB should make a system that automatically stops the car even if you don't apply brake let alone that you acclerate towards the obstacle it still cuts the power and brakes the car may be next gen will call ULTRA Safe
I see, they don't wanna rule out the drivers involving but it's better to prevent an accident , collision ,rear end rather than it happens at minimal damage
I think it is a safety feature that it does not apply full brakes if you don't touch the brake pedal yourself. In addition to the two true events I experienced where an accident could have happened and I prevented it by touching the brake pedal I have received the double beeb warning three times where there was nothing in front of the car, at least that I could see. I did not touch brake pedal and the car did not apply the 40% braking either.
I don't know what happened but it could have been a large size bug that the system saw but as it went away immediately it did not apply the brakes? If the car would automatically do the full braking without your input it could make the car wery unpleasant to drive.
I think it is coming though after they figure out how to make sure the danger for the accident is real, like installing two radar units in opposite sides of the front of the car and treating it as accident danger if both radars see the danger at the same time. This would eliminate the bug problem as that size bugs hardly exist to cover both sensors in the front at the same time.
The car will also double beep on residential streets if there is a car parked on a left-hand curve. I think for some reason the parked car prevents the system from seeing the curve, and so again it assumes you will be driving straight into the parked car. Again I would not want 100% braking here.
Another tricky false positive for blind spot assist: turning left or right from the center when multiple lanes turn the same direction. Blind spot assist thinks you are turning into the car at your side, when really the car is turning too. If you get the system that brakes to try to correct the steering, you better be holding on tight! I have no idea how the engineers could correct for that unless the car could somehow read the tire angle of the car beside you. Yes, blind spot assist shuts off at low speeds, but I have gotten this false positive many, many times - I guess our intersections are big enough that we are probably doing 30+mph in the turn.
