I refilled the DEF using a fuel type pump
My M-B dealer sells a 1/2 gallon (2 liter) bottle for about $10, and the tank holds somewhere between 6 and 7 gallons. In fact, my dealer quoted me $10 a bottle for however many bottles it would take to fill (even though they fill from a big 55 gallon or so drum of DEF.) FYI the 7 gallons or so of DEF that the car holds lasts well more than the 10,000 miles recommended between oil changes and services.
So, I'd read that many truck stops today have a DEF pump right next to the diesel pumps for the big 18 wheel trucks. I googled and found such a truck stop about half an hour from my house. But the car's tank has a proprietary cap and you can't just stick a nozzle in there and fill it up. One person recommended buying one 1/2 gallon bottle and then cutting off the bottom, and using it as a funnel. Sounded good, so I did that....
And I learned a few things:
1. This is a two person job. You have to push down on the bottle to get it to drop the fluid into the tank, but if you push too hard and the fluid goes in too fast, then some fluid shoots up the small tube which is meant to let the air escape out of the tank while the fluid goes in. There is a delicate balance to how hard to push, otherwise you are making a huge mess.
2. The truck stop pumps don't work like gas stations that you and I are used to. You have to go inside and they activate the pump from there, and they'll look at you funny because you're not dressed like a truck driver, and your truck doesn't have a truck number. You can't just drive up and swipe your Amex card.
3. It took me a long time to pump five gallons into my car, like 20 minutes. Any faster and the DEF shoots out the exhaust tube in the bottle.
4. The only way that you know that the tank is full is when the funnel won't allow any more DEF into the tank. So you then have to unscrew the funnel, and discard the little bit that's left inside it.
5. Now the good news: My 5.061 gallons of DEF cost me $14.67 or $2.899/gallon. So I filled the tank for $15 instead of over $100.
Overall, I saved about $100. Was it worth the hassle? I'll let you decide that. For me, I am not really sure what I'll do at the end of the next 10,000 miles.
I like your idea though. Do you think just cutting a smaller hole in the bottom (not much larger than the pump nozzle) will reduce the splashing from the air tube?
I know what you mean about having to waste the last amount but still wroth it I suppose.
I am not sure what I'll do next time either. My dealer estimated $50-70 I think to fill the E class, which isn't too bad.
Hopefully as time goes on there will be better solutions...
1) cut off the bottom of the 1/2 gal container and then pour from the big jug into the 1/2 gal container slowly (while someone is holding it down). Concern is will that big container drip.
2) try to get the fill mechanism off the 1/2 gal container so I can refill it out of the car and then connect it/push and refill the tank. Will take longer, but no spill issues unless the fill mechanism comes off in which case you have a real mess to deal with.
What seems to work the best...or is their a third approach. Heck, I could probably just siphon it in and maybe that's the best way.
Open to suggestions....that fluid is calling to me from the garage (but no indicators on the car, so I'm ok to keep driving for a while.
In your case, I might try a thin siphon hose from the 2.5 gallon, but you'll have to go very slowly and be ready to mop up the mess when the tank is full, if you get to that point with the 2.5 gallons. There is not going to be any convenient way to pour slowly from the big jug.
