6K miles on 2011 e550 4matic. Brakes pulsing already
If it's the latter try a few very hard stops in a row good and hard... afterwards drive the car for a few miles allowing them to cool down, see if that fixes your issue.
I could understand wanting it to just be fixed,seems annoying.. maybe the re-occuring problem will finally get some serious attention if it hasn't already...
ever get any good freebies from the dealer?
did you buy or are you leasing? just wondering because would you get your stuff back if you have to give the car back?
I love BMW but you're going to experience a whole crap ton of issues with whatever model you buy. The more the BMW costs the more issues they have. Check the BMW boards if you don't believe me!
Had my brakes replaced under the 12k warranty and it's now vibrating again. I will have it in service very soon here and I'm hoping they take care of it again and from reading the above forum, Brando253 had said he talked to two service manager in his area and was told that the 550 brakes were undersize and it cannot be retrofitted. So to my understanding, this will continue to happen even after it gets replaced. If this is the case, I probably will take a hit and trade it in. For the amount of money I and others who are having this problem paid for, it's not fair.
Under sized brakes mean they cannot stop the car fast enough or that the brakes wear faster than they should. If you get pulsation on brakes it means something is wrong with the rotors material, i.e. the rotors wear unevenly around and this simply means the rotor material hardness or more precicely wear resistance is not the same around the rotor. Keep taking it back to the dealer under warranty or get after market rotors for it.
Had my brakes replaced under the 12k warranty and it's now vibrating again. I will have it in service very soon here and I'm hoping they take care of it again and from reading the above forum, Brando253 had said he talked to two service manager in his area and was told that the 550 brakes were undersize and it cannot be retrofitted..
As stated before, I believe it's a metallurgy issue...hopefully an upgraded rotor will be avalible soon.
I agree with this and also the actual cooling of the front brakes seems to be poor, which may have something to do with the aerodynamic efficiency in the area. I had zero issues, bedded my pads from 25 miles on the odometer and wasn't until the summer heat, did they diagnose pad material uneven on the rotors and replaced them.
Hot brakes fade more quickly and will warp rotors... but what do I know.
We're a Brembo dealer and some of our customers have the same issue. Racetech would send us a set of hawk blues and I'd run them hard cleaning the rotors. I've also done it with OE Brembo pads, just takes a little more work.
