Sponsored by: CARiD
E63 AMG 19's will fit E350 ?
Old Oct 7, 2012 | 12:35 PM
cdsjklee's Avatar
2004 SL55 AMG EUROCHARGED. 2002 X5. 1999 SUBURBAN WHIPPLE SUPERCHARGER+MODs,04 M3 EUROCHARED
Hello.
Anyone knows if W212 E63 19 inch AMG wheels fit on W212 E350 ?
Old Oct 7, 2012 | 08:23 PM
Karl901's Avatar
Porsche 911 Turbo S 2014! E63S 14, Audi S8 13, CLS63 12, E550 12, C63 09, all tuned
I put them on E550 4 matic. I do not think there is a difference between 550 and 350.
Old Oct 8, 2012 | 03:29 AM
snake529's Avatar
w212 E300
W212 E63 wheels are 19x9 and 19x10
On E350 you will not have any issue in the rear, you can even use the stock tires 285/30/19
But you will have issue in the front due to 350 fenders which are little wider than the original E63 fenders. you can replcae them but you will have to streach the front tires if its possible. i recmmend you to use 245/35/19 and you are ready to go.
I convert my E350 totally to E63 with original parts so i dont have any problem with the rear.
Old Oct 8, 2012 | 12:18 PM
cdsjklee's Avatar
So rears are OK with stock E63 size but front E63 stock size is 255/35/19 which total height of tires are 25.4 inch vs 245/35/16 height is 25.8 inchs tall. so 245/35/19 is .4 inch shorter. which area will be problem on the Front ? I do not have the wheels yet i am getting it by end of week. I could not do the test fit before purchased these wheels since it is coming from 300 miles away.
Old Oct 9, 2012 | 05:25 AM
vei1side's Avatar
2019 E63S
they will fit fine.
Old Oct 9, 2012 | 11:30 AM
cdsjklee's Avatar
Originally Posted by vei1side
they will fit fine.
I received wheels yesterday it fits fine. Tires are 255/35/19 and 285/30/19
it actually looks really good with that size tires.
Only problem is now my display show no TPMS signal. Does it mean it does not have TPMS on these wheels or TPMS for 2011 E63 is not the same as 2012 E350 ? I thought TPMS are standard on all Mercedes.
Is there way to find out if it has TPMS installed on the wheel without dismount the tire ?
Old Oct 9, 2012 | 11:50 AM
threeMBs's Avatar
Only MBs - the best or nothing
TPMS sensors are identical. Its a common "practice" to remove OEM sensors from OEM wheels and putting them into aftermarket onces. I assume that's what was done to E63 wheel. Just look at the valves of your new and old wheel - if they're identical (unlikely) then sensors are there. Its a plug and play - you should not have to do anything if new wheels have sensors. If valves are the same, just restart your TPMS. I've used multiple wheels (all with TMPS OEM) on several W212 cars - never had to reset TPMS.
Old Oct 9, 2012 | 12:10 PM
vdubpower's Avatar
i drive them all, fast and hard
Did u put e63 badges too
Old Oct 9, 2012 | 10:57 PM
Karl901's Avatar
The answer is yes.
Old Jul 27, 2014 | 08:44 PM
Hfdafhx's Avatar
Pinto
are you sure the e63 wheels are 19x10 in the rear
I thought 19x.9.5 rear and 19x 9 front
Old Jul 27, 2014 | 08:55 PM
PeterUbers's Avatar
E350 converted to e63... Interesting
Old Jul 27, 2014 | 08:57 PM
Hfdafhx's Avatar
Pinto
The look !
Old Jul 27, 2014 | 10:38 PM
Crazy4Cars's Avatar
W212 E350 AMG E63 Pack.
It is the opposite, E63 fender is wider than the E350.
Old Nov 17, 2014 | 08:01 PM
Saul75v's Avatar
2011 E350
18x9
Does anyone know if 18x9 rims will fit on a 2011 E350 Sport? I spoke to a parts guy at Mercedes. He said they might fit but was not sure.
Old Oct 16, 2018 | 01:53 AM
Kei2thehwy's Avatar
2016 CLS S-Model
I think so, too. Positive. CLS is 10" in rear, I hear.
Old Oct 16, 2018 | 01:54 AM
Kei2thehwy's Avatar
2016 CLS S-Model
The Look!
The look !
That's what I want. What rims? Thx.
Old Oct 16, 2018 | 10:21 PM
ahmadk's Avatar
2011 E550 Sedan
Diameter and width aren't the only factors that determine if the wheel will fit.
I have 20x9 with +32 offset in the front and they fit but are close to the fenders (just to give you an idea)
Old Oct 17, 2018 | 10:12 AM
MaschioneCazzuto's Avatar
2016 E63 AMG-S, 2007 FERRARI 430, 2001 JEEP WRANGLER 60TH ANNI. EDITION SOLD 2011 E550 4matic
the AMG badges and his blow up dolls in the E350, great amusement post pictures OP.
Old Oct 27, 2021 | 03:38 PM
KDKoupe's Avatar
2017 E400 coupe
The look !
nice! I wanna do the same to my 17E400 coupe
