First pull of the dip stick was bone dry
2012 E350 Sport, P1, AMG Wheels, Multi-contour seats
I thought I'd check my oil level this afternoon - for no good reason other than I had never opened the hood and was looking for an excuse to (it's a 6 week old 2012). When I pulled the dip stick, it was bone dry. No trace of oil on the red tip. I wiped it off on a white cloth and there was no oil on the cloth. I was quite alarmed.... As all sorts of horrible thoughts ran through my mind, I decided to check the oil level again. I dipped the dip stick and this time it came up with oil at the full level.
I don't understand how/why the first pull was totally dry. Has anyone experienced this or have an explanation?
First time checking the oil in a car? Do u think the dip stick needs to be lubricated during engine operation?
J/k, some engines need a sufficient vent for the oil to settle. Some will look bone dry, some will look overfilled, and some will represent the oil level on the first pull.
Anyone that has ever checked oil before knows that you remove the dipstick and then check the oil.
That time I wasn't kidding.
The dip stick simply goes down in a tube that ends before reaching the oil level. The end of the dip stick then extends to the oil. If your stick was totally dry it must not have been pressed in all the way against the upper end of the tube.
Received 3,419 Likes
2012 CLS63
haha: reminds me of the Seinfeld where Kramer puts blood in for the oil LOL....
"man, this thing is bone dry!"
sorry to go off topic
I do check mine in every 1000 km roughly , I did check the oil level and 1st attempt made it look like there was some oil missing lol
I put it down to the resistance point again and waited a few secs pulled it up and voila it was between MAX / MIN level exactly textured area
I guess I didn't realize it had a dipstick. I don't think the 211 has one as I could never find it and always checked the oil on dash display.
2017 CLS550, 2016 HD Roadglide (120ST), 1972 Super Beetle
Or when Jerry's car had that BO smell that he couldn't get rid of. Or, when Kramer adopted a section of highway and painted over the yellow lane dividers to make luxury lanes. Or, when George bought John Voughts Chrysler LeBaron....
2010 E350 Luxury Sedan, Engine 272 (V6)
Think it is interesting that dipstick is almost hidden at back of engine near firewall. There is NO transmission fluid dipstick, so have to rely totally on electronics to warn of low level.
Until I learned you could open the hood to near vertical, I had a bear of a time pulling that dipstick and checking. Probably not as much an issue for someone taller than me.
Actually I have experienced exactly the same on both my 2012 E350 and my wife's 2010 GLK350. I know both dipsticks are completely seated but when I pull the first time they are both bone dry. I wipe them, reinsert them and pull and there is wet oil on the stick. I can only attribute this to the fact that both cars use synthetic oil and perhaps the chemistry of the oil prevents sticking unless somehow agitated. Other cars I've owned that used normal, non-synthetic oils have never done this. Does anyone have a non-Mercedes vehicle using synthetic oil and does this ever occur??
2012 CLS63
haha, my Targa doesn't even have a dipstick, have to rely on the cars computer
Now that I have seen other people experience the same thing it is my guess that the dipstick sits in the tube in an air lock, when pulled no oil can come up the pipe till the cap is opened then the oil can rise up the tube and be at the correct level on the recheck.
My 2013 E350 is the same way. The first pull the dip stick is dry. the 2nd pull shows the oil at the correct level. I check weekly and over the nearly 6 months I've owned it, it's always been this way.
2016 C450 AMG
I have a 2012 E350 in the first year not much driving there was less than 10k miles on it. About 10 months in I started to feel strange vibrations in the steering. When it came due for the 1 year maintenance the tech noticed there was little to no oil in the car.
Once they filled it up the vibrations went away. But the car never notified me of low oil engine nor did the engine light come on. I now check the oil often to make sure it doesn't fall low again but I have owned 4 other Mercedes vehicles and have never had that happen before not sure if its related to the DI engines now in the vehicles.
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
My service guy says its normal...somehow, our cars lose oil...up to 1 quart...between changes. I thought he was joking, but he wasn't. Where does it go? Does it evaporate? I carry a quart of oil in my trunk just in case.
Okay, I have had a number of various cars, including two older Mercedes, and I'm very competent mechanically but I cannot find the dipstick on my 2012 gas E 350. Owner's manual says's its on the right side near the fire wall but I sure don't see anything. What's the deal?
Thanks,
Karl
Thanks,
Karl
Thanks,
Karl
Thanks,
Karl
Thank you, the OM shows it on the passenger side, I'll look on the other side and see what I see. Wouldn't want it colored yellow or anything....
Karl2012-E-Class-Sedan-and-Wagon pg 309.pdf
I was totally shocked in the beginning.
Second dipped, it came with "OIL"
My dip stick does the same thing. Here is my explanation. The top of the dip stick is sealed when the dip stick is in. Like a straw that you hold your finger over and then stick it in a glass of water no water can enter the straw because of the trapped air. The oil has dained out when the motor was running. When it stops the oil can not enter the dip stick tube until you pull the dip stick out.
If you ness around with it enough you can confirm this. All is well with your engine. Why a design like this I don't know.
This dry dip stick issue just shows how bad the MB dealers are with doing the final check-out of the car before the delivery. They surely are supposed to check the oil level on every car they sell before it is given to the customer.
Dry dip stick can only happen as explained above, i.e. the oil cannot enter in the dip stick tube while the dip stick is sealed at the top of the tube. Obviously MB serial product line installs the dip stick in the engine first and oil is added later and they trust the oil volume and nobody lifts the dip stick to check.
Confirmed it was full of oil by removing with Topsider and got about 7.5 qts at A service.
