Sponsored by: CARiD
Trick and helpful tips for W212 owners.
Old Oct 24, 2012 | 05:11 AM
Khasona6's Avatar
MBZ E550 2010,INFINITI G37 2009, LEXUS IS350 2012
Post Trick and helpful tips for W212 owners.
Hello everyone, I started this thread to share the knowledge and experience about tricks I found for my car, so anyone knows something this could be reference for. These things applied and worked in my 2010 E550 P1.
1- In hot weather you can actually open all windows, sunroof, and activate the vent/cooled seats by: Press the closing doors and immediately open and hold the door panel until everything opens.
2- HOLD function, applies on D and N, stop and hold the brakes then depress the brakes until a HOLD is activated.
3- Accessing Engineering Mode 1, press and hold REJECT CALLS+ENTER+#1
Engineering Mode 2, while in EM 1 press and hold REJECT CALLS+ENTER+#4
4- You can jump directly to any music player without using the COMMAND controller, for example: you are using the NAV and want to change the COMMAND music from BT audio to Media Interfere, press #0 for MI 9# for BT audio and every # has function for.
That's for today.
I hope this thread would be helpful as its for me and I'm happy to share my experience as I hope you share for others.
Thank you.
Old Oct 24, 2012 | 05:31 AM
BM2BZ's Avatar
w212 E550
thanks for your effort, khasona6 . check out this thread if you haven't done so:
https://mbworld.org/forums/e-class-w...w-e-class.html
Old Oct 24, 2012 | 05:33 AM
Khasona6's Avatar
Oooh hack! I should have searched first before starting a thread.
Thanks BM2BZ
Old Oct 24, 2012 | 05:52 PM
BM2BZ's Avatar
w212 E550
i give you credits for trying to help out other fellow members, though . it's well better than some newbies just create a thread to ask a question w/o even doing a quick search. they didn't say thanks and disappeared after they have their answers . worse yet, they'll even complain if no one replies in an hour .
Old Oct 25, 2012 | 07:07 AM
Khasona6's Avatar
I think it makes me feel better about my self when I help others, though a THANKS wont lose u anything.
anyway I ll ore careful in the future when thinking of a new thread
thank you and happy hallowen
Old Sep 23, 2013 | 06:59 PM
bcometa's Avatar
2014 E350
Could you explain procedure a little more? I was told by Mercedes that this was only possible in Convertable models and would like to be able to do it on my 2014 E3501 sedan.
Thanks!
Old Sep 24, 2013 | 07:12 AM
USCGTO's Avatar
your mom
Thanks!
THis has worked in my 07 E550 - 09 GL450 - 11 C63 - and 12 E350.
You essentially press the "open" / unlock button and keep it pressed and windows / sunroof start opening.
AT times, it's been noted that I need to be pretty close to the door.
Old Sep 24, 2013 | 12:58 PM
bcometa's Avatar
2014 E350
USCGTO, that is using the key fob -- I was hoping Khasona6 found a method to do it (roll down all windows + sunroof at once) from inside the car.
Old Sep 24, 2013 | 02:10 PM
mikeyle's Avatar
2012 e350
on my 2012 another way to open sunroof and all windows from the outside is to put your finger on the sensor on the door handle and pull the handle so its halfway out, holding it like this opens all the windows.
Old Sep 24, 2013 | 02:14 PM
bcometa's Avatar
2014 E350
oh cool, looking forward to trying that out .
Old Sep 30, 2013 | 06:53 AM
aeroconfigs's Avatar
w212
I think the best hack by far was enabling the bluetooth streaming in the engineering menu. Older w212 like mine (2010) don't have the feature by default. It actually works really well although the song titles arent transmitted. You can still change tracks, pause and play with the comand.
Old Sep 30, 2013 | 08:33 AM
w0rtez's Avatar
W212
can you show us how your EM1 where bluetooth option is located look like, i tried mine but didn't work, and i haven't updated system software, i believe you haven't updated neither...
Old Sep 30, 2013 | 08:34 PM
w212
This is from the other post linked above...
Originally Posted by jinx420hat
Alright guys I'll do my best at this... (BT=Bluetooth)
-End Call + # + 1: opens Engineering Mode
- HU Settings
- HU Parameter
(the following are the settings I put them in)
(1) BT contact plate: Not Installed
(2) LCT: Installed
(3) BT audio: On
(4) Audio Aux: Off (greyed out: not an option)
(5) Video Aux: Off
(6) Navi: installed
(7) BT: on
-back buttonx2
-pull command wheel down
- system reset
- reset - yes
- go to audio, then go to the audio tab again to bring up the drop down menu of audio options, select BT audio and activating audio device comes up, then the audio streaming screen
I have included screen shots of all the important steps (sorry for the poor quality but it was night time and the flash on my phone kept going off) Let me know if I need to clairfy ne thing.
Old Oct 2, 2013 | 09:43 AM
w0rtez's Avatar
W212
My EM1 don't have that option, i only have one this... And I can't find system Reset after I set BT Audio Feature Set2 ON, so it can stay on...
Attached Thumbnails Trick and helpful tips for W212 owners.-wp_000004.jpg   Trick and helpful tips for W212 owners.-wp_000001-2-.jpg   Trick and helpful tips for W212 owners.-wp_000000-2-.jpg
Old Dec 7, 2013 | 03:54 PM
FastE's Avatar
2020 MB-AMG GLC43
Great tip! I knew about the remote - but who wants to take it our of your pocket? This is much better.
Old Dec 7, 2013 | 03:55 PM
FastE's Avatar
2020 MB-AMG GLC43
Are you driving a W212 like the thread asks? This looks quite different...
Old Oct 27, 2018 | 08:19 AM
lmc82's Avatar
2000 W210 and 2009 W212
It’s the same UI as my W212 E-Class 2012, cant get Bluetooth audio from phone.
