AMG Sport Rotors need to be replaced at 30,000
My front rotors already need to be replaced on my 2011 E350 Sport. I only have 30,000 miles on it and dont drive or break that aggressive? Any thoughts?
Have a great New Year!.
Thx.
Sorry to what happened to the rotors . I read long time ago about warped rotors .So, as I recall different tightened or overtightened lug nuts could cause rotors to be warped .This is why they recommend torque wrench
Happy New Year
Torque of the lug nuts have absolutely NOTHING to do with warped rotors. This, of course, means that the nuts are made tight in general. This does NOT require a torque wrench.
Having owned an AMG version of a Mercedes, people are missing the point as to what an AMG is, the model I had is a completely rebuilt car and compared in no way to the top of the range model it came from, and I don't mean power output which is obvious but the total build quality, the car was virtually rebuilt from the base chassis up, was chalk and cheese by way of comparison!!!! That is what AMG is about!!!!"
Having said all this, I think that Mercedes callipers and disc's are more prone to warping than many other top end cars!
This is probably due to metal composition and manufacture, being design to fail at an earlier rate.
I have known a fault on a brake system, where the pad was not fully disengaging from the disc when the brake pedal was released, something to do with the brake control system, causing the rotors to overheat on a number of occasions, eventually till they warped!!!!
BMW for example are to my knowledge the only manufacturer who balance each individual disc during the manufacture process.
The comment surrounding wheel tightness does not affect the brakes, having had a wheel come loose (on a previous high powered car) I am well versed on the impact it had on the braking system before and after the event. So I would blow smoke on that comment!!!
However, wheel tightness most certainly affects the brakes or brake rotor to be specific. *If* the wheel is not torqued properly it will cause warpage. All the lug nuts *must* be at the same ft-lbs so the pressure is even. The reason is the wheels are aluminum. If you have two lugs at 100 ft-lbs torque and 2 at 70 and one 110 ft-lbs then the wheel will not run true. That puts pressure on the rotor not to run true.
A steel wheel on a drum brake won't cause any problems. I can tell you that I always torque my own wheels. I have watched the dealers and they do not torque the wheel. I had one lug on so tight that I bent a tool trying to loosen it.
All alloy wheels should be installed using a torque wrench. Check your vehicle's manual for correct settings. When you install wheels for the first time, you should re-torque wheels after about 100km to 150km (60 to 90 miles).
In 15 years of doing this I have never had a bad rotor again. Take a torque wrench and check the lugs after the dealer has done the work. You will most likely find the lugs either tight as hell or loosen with a gentle tug. This practice helps sell rotors.
Just to endorse your point, I had an incident !!!I was driving my car a BMW 6 Series, when the first nut started to loosen on the wheel, (clearly I was unaware) I was travelling on a 400 mile trip, as the nut loosened it impacted the brakes fairly quickly but subtly, cutting a long description short, when I went into the BMW dealer, 100 miles into my journey as an emergency ( my car had runflats and no damn wheel brace, always carry one now!!!!), they had to take the car out again to diagnose the problem, when they first returned they said they could find nothing until he had to brake hard turning into their forecourt, then he felt the effect. Once diagnosed we got into a discussion, he said that the brake rotor had moved off centre on the hub, (remember they are held on by one bolt), he said it was only a few mills but is enough to unbalance the disc, which over time would have resulted in a disc failure, ie warping. He then explained to me the in and outs of correctly torqued bolts and the effect they can have!! needless to say I torque and check regularly my wheel bolts, to the correct settings.
finally how did it happen, I had had my wheel refurbished and when they put the wheel back on there were two things wrong, one they were definitely under torqued and second the face on one of the bolts had paint on it which almost acted as a lubricant which caused the first bolt to come loose then it followed that the other four bolts then started to undo!!!!!!!!!!!!! Lucky to be Alive as I was travelling very quickly nod nod wink wink !!!!
