Need help with my side markers
Rob.
But I figure out a way to trick the computer if you want to go LED clear.
1) turn the steering wheel to the opposite side your are working on
2) pull the front fender liner from the fender with a good yank; make sure youdon't lose the fastener that pops out
3) turn the bulb socket counterclockwise and pull the bulb and socket out fromthe inside of the lens
4) use your fingers to pull out on the rearmost side of the lens and-once it isfree from the fender-pull backwards towards the rear of the car to free thefront of the lens from the bracket inside the fender
5) reverse the process with new lens and then reinstall the plastic fastenerthat popped out
https://mbworld.org/forums/e-class-w...ng-lights.html
