Sponsored by: CARiD
2010 e550 Keyless GO
Old May 15, 2013 | 02:42 PM
KEEP IT REAL's Avatar
e55
So Keyless entry is one thing when you can get in your car with a key in your pocket and keyless GO is push to start button, right?
Dealer tells me that 2010 e550 has keyless go with keyless entry but he doesn't have the actual button, which can be taken on and off?? Right now it starts with a key only, as dealer explained i can this silver button from MB and i will have push to start, and wont need to use a key
Is that right???
Also if its keyless entry shouldn't it be by default to have keyless go-push to start?
I mean you get in the car without need of key but then you have to take it out to start the car that doesn't make any sense lol))
Also how do you tell if its P1 or P2, what was the extra you get in P2 for 2010 e550? Would be also nice to find all options/features you could get for 2010 e550 Thanks!
Old May 15, 2013 | 03:07 PM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
Keyless GO (KG) was part of the P2 package for the 2010 MY.
Not sure what your dealer is saying, because KG is more than a silver button in the dash, the system includes antenna and controllers built into the car.
Operationally, with KG you can just touch a door and the car will unlock (in different configuations as programmed by the owner) and will enable you to start the car by pushing the in-dash button.
For 2014 MB separately offers KG from the P1 package ... go figure.
Old May 15, 2013 | 03:58 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Easiest way to tell if the car has KEYLESS GO is to look at the door handles. Do they have a chrome trim piece on them and a rectangular dent in the face? If so, you just need to buy the silver ignition insert button from the parts department.
Equipped with KEYLESS GO:
Not equipped with KEYLESS GO:
Old May 15, 2013 | 11:39 PM
Nuru's Avatar
S350 BT 4MATIC
Yep, YYZ-E55, is correct.
Old May 16, 2013 | 12:50 AM
Arrie's Avatar
Is that right???
Your dealer is full of crap. MB only has Keyless-GO. There is no Keyless Entry.
It is obvious they have somehow lost the silver Start/Stop button from the car and tell you a "story" that the car does not have it and you can get one from MB. Keyless-GO is part of the P2 package and includes the Start/Stop silver button.
The button is removable so you can use the key in case something goes wrong with the Keyless-GO system or at the service they can remove the button as obviously the servive people prefer to use the key instead. It may also be that for some service functions key must be used.
Bottom line, a P2 car came from the factory with the Start/Stop button,
I drive the 2010 E550 with P2 and I have the Keyless-GO including the Start/Stop button. This is also what my previous 2011 E350 had.
Old May 16, 2013 | 07:05 AM
YYZ-E55's Avatar
Every MB today has keyless entry as standard equipment (ie: you can unlock your doors without using a mechanical key - you press "unlock" on the fob).
KEYLESS GO adds the proximity sensors in the doors so you don't have to physically press the button on the key, as well as the ignition button.
Old May 16, 2013 | 08:41 AM
Arrie's Avatar
Man,
what you call "Keyless Entry" used to be called "Remote Locks". Almost all cars now has this. It is Keyless only if you don't have to press the button on the FOB. The FOB is your key, remote key.
MB "Keyless-GO" is a system where you really do not need to touch the key at all, just have it on you when operating the car. OP's 2010 E550 came from the factory with all parts of it, someone has just misplaced the Start/Stop button.
Old May 16, 2013 | 11:17 AM
DG_Guy's Avatar
2010 E550, 2007 R350
Looks like you can buy a new one on Ebay for about $50. Search for 2215450514
Old May 16, 2013 | 01:28 PM
e55
YYZ-E55, ok yes it has that but inside doesnt have Push to start silver button, so i am confused?? Is it true that i can just buy this silver button as DG_Guy posted. btw DG_Guy thanks mate!
samkimg, u got 350? was it same for 550?
Old May 16, 2013 | 02:51 PM
YYZ-E55's Avatar
Sounds like if you buy the button, you're good to go. It just pops into the ignition.
Old May 16, 2013 | 05:11 PM
e55
I found options list, if anyone need it http://www.mbusa.com/mercedes/cpo/mo...ions__packages
Old May 18, 2013 | 12:42 AM
qnguyen018's Avatar
mercedes e350
does the button need to be programmed or anything?
Old May 18, 2013 | 12:57 AM
Nuru's Avatar
S350 BT 4MATIC
Now that is an interesting question. Seems like all you would only have to program is the key to the car.
Old May 18, 2013 | 01:07 PM
ttoE550's Avatar
2015 GL450
I would imagine it's just an antennae. Someone who has two E's could switch buttons and see if it matters. You could call a MB parts department and ask. I bet the salespeople lose them once in a while.
Old May 18, 2013 | 02:55 PM
Arrie's Avatar
If you bought the car new and the Start/Stop button is missing then you lost it or the dealer lost it before delivering the car to you.
If you bought it used from a privatre party then you need to buy one yourself.
If you bought it from the dealer they owe you the button. I would raise a hell about it.
Old Feb 22, 2020 | 07:42 PM
hemigtx's Avatar
2017 GLE 43 AMG
So if the door handle on my 2011 E-350 has that type door handle on it with the square dent, all I need to get is the button that goes where the key goes and everything will be good to go? Correct?
Old Feb 22, 2020 | 08:02 PM
DFWdude's Avatar
2016 E350 Sport
If your car has the rectangle in the door handles, then you should be able to lock the car on exit (touch the rectangle) and unlock it (insert fingers behind door handle)... WHETHER OR NOT you have the button for the ignition. They are separate functions that work independently. Go try it.
Some folks like the door handle functions, but prefer to insert the key in the ignition to start the engine. Adding the button only means that you should be able to press the button rather than insert the key. The only common requirement is that the key needs to be on your person for either to work...
Edit: Be sure to read the reviews of any buttons on offer on fleebay. Some of these buttons are faulty and do not work.
Old Feb 23, 2020 | 03:25 AM
cetialpha5's Avatar
I think the faulty ones are just people who buy it and think that all they need is the button when your car needs to have that option in order for the button to work. I don't think there's really anything electronic in it, it's basically just a button. I'd be surprised if there was something in there, that'd be a lot of tech to have in a button that only sells for $11.
I prefer to just leave the keys in my pocket. The nice thing about the button is that it always just cranks the engine the right amount to start it every time. You also never end up grinding your starter because you forgot the engine was already running, if you press it again while it's already running, it just shuts off.
Old Feb 23, 2020 | 08:22 AM
RA72825's Avatar
Yes, button is a pusher and that is all. It has absolutely nothing in it. A hunk of plastic
Old Feb 23, 2020 | 08:53 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I actually don't use the start/stop button. I find inserting the key and twisting satisfying. Other people think I'm crazy.
I wish Benz had stuck with using the button on the shift knob like the W211 and that way you could do either without having to worry with the removable button.
Old Feb 23, 2020 | 10:43 AM
nota_amg's Avatar
2013 SL550 BiTurbo
If you want to know for sure, put in your VIN here ---> [LastVIN.com] and look at the build sheet to see if it has "KeylessGo" on the list. Easy-peasie!
Old Feb 23, 2020 | 02:49 PM
cetialpha5's Avatar
Yeah, you might just be crazy. I have both, I suppose sometimes if it's already in your hands, you can just stick it in the ignition so it has somewhere to go. Sometimes the keys for the W212 either end up in the passenger seat or in the cup holder so then you have to go back into the car to grab them when you wonder why the door doesn't lock and then realize you don't have the keys on you. The button and shifter is definitely better on the W211. The stalk on the W212 is kinda wimpy. I let someone borrow my car once and she couldn't even figure out how to shift it out of park.
