NEW RIMS, Mo problems?
2011 E550
Hi you massive lovable creatures!!!! I JUST posted a thread about my car being bottomed out so i apologize if its really soon to post another one. Anyway i got some new rims for my car that at the speeds of over 55 miles an hour, the car gets this like bumping/shake sensation through the steering, and only gets worse as the speed increases. I called the shop owner, as he also owns a W212 and has aftermarket rims, he said he was going to put a plastic round piece (spacer?) between the rim and that wold help sort things out. I don't know how thats going to help, but I'm no rims expert, and thought i would turn to the people who are. What do you guys think will this stop the vibration or is he BSing? AS always all advice is appreciated!
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,399 Likes
2012 CLS63
maybe the wheels are bent
14' CLS550
only reason he would suggest a "plastic ring" is because your wheels aren't hub centric(he should have put the plastic ring on the 1st time he mounted the wheels,instead of waiting for you to complain)they would absolutely wobble if that was the case. i don't feel like explaining what hub centric is.
2012 CLS63
so man where are the pictures?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
I think the OP needs to spend more time learning about his car before he begins modding. As cars have gotten more complex and manufacturers have made huge strides in reducing NVH so hubcentric quality wheels are a requirement.
Any shop that sells and installs wheels that require hubcentric rings but don't install them should be avoided like a disease.
2011 E550
2011 E550
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The hub is the thing that the wheel attaches to. OE manufacturers make the wheels fit the hubs. Generic wheels are made to be fitted the largest hub size and then use metal or plastic rings to fill the space between the smaller hub and the larger wheel opening. Using this ring assures that the wheels are centered on the hub.
If the wheel isn't perfectly centered then then you'll get vibration. It is best to buy wheels that are properly sized so that you don't need to use centering rings.
It doesn't need to be off center much to cause issues.
2011 E550
QUOTE=CEB;5665675]NVH - Noise Vibration and Harshness
It doesn't need to be off center much to cause issues.[/QUOTE]
if I knew the wheels were not the proper hub size on my car I would definitely not have bought them.now when the plastic ring is installed, will it help, or will I never get the stability of my OEM rims? Also let me say I appreciate the info you have given me,I would never found this stuff out myself!
Bob - it depends on the quality of the wheel and the centering rings but the short answer is that I doubt it.
Why don't you tell us what you bought and we'll go from there.
2011 E550
Why don't you tell us what you bought and we'll go from there.[/QUOTE]
niche targa m130
You'd be better off buying a set of MB wheels.
Also, just click "quote" when responding to a message instead of whatever you are doing.
2011 E550
Also, just click "quote" when responding to a message instead of whatever you are doing.[/QUOTE]
the mobile version of this site rally doesn't have quote button,that's why I couldn't quote.. I wanted to get mb rims,I just didn't like the design,I wanted something a little different. so there is no hope for these rims?
I can't seem to quote,I don't know what is going on :/
2012 CLS63
E350 4Matic 2011
Hi Bob,
Take a look through the tech pages from a company that makes (from everything I have heard) an excellent balancer: the Hunter Roadforce GSP9700. You will quickly learn all about vibrations and what it takes for a smooth ride: http://www.gsp9700.com/
Good luck!
Good luck!
Hi Bob,
Good luck!
Good luck!
In this case - assuming that Bob got straight wheels and decent tires - the problem may well be the spacers and that problem won't be resolved by road force balancing.
2010 C300 & 2014 E350
In my experience, even if you have hub centric rings you still might get the vibration or shimmy in the steering wheel. You need an "on the car" wheel balance to make the problem go away, but within 3K miles it will come back. It's better to get rims that don't need hub centric rings.
2011 E550
2012 CLS63
oi.......who's the idiot now?
