Sponsored by: CARiD
Slight pull to right at highway speed?
Old Jun 3, 2013 | 11:46 AM
MCF's Avatar
MCF
E350
Took our first extended trip in the 2011 E350 this weekend and am very impressed with the comfort in the car and how it cruised effortlessly at 80-90mph. I did notice one thing. The drive was from Houston to Georgetown (Austin) and back and noted the car had a slight tendency to pull to the right at above about 65mph. It runs straight as an arrow in town and I realize that highways are 'sloped' but it seemed the car would even pull to the right slightly even when in the passing lane. Anyone else experience a 'high speed' pull on the highway? I checked tire pressures and they are all correct and equal.
If I want to get the alignment checked, any reason to take it to the MB dealer or is a tire/wheel shop actually better equipped to do a front end alignment. Thanks!
Old Jun 3, 2013 | 12:42 PM
bob2011's Avatar
2011 E550
my car also pulls to the right on the highway at times. I did search up what it could be and it's most likely because all roads (most) are crowned to the right so the rain can wash out. so I'm thinking that's why it's doing it.
Old Jun 3, 2013 | 12:56 PM
ScottNJ's Avatar
2012 E350 Cabriolet 2013 BMW F10
Mine severely pulls to the right even at idle speed, I have no clue why because my rims are not bent and I avoid every pothole.
Old Jun 3, 2013 | 01:04 PM
bob2011's Avatar
2011 E550
hmmmm then you should take it in. mine pulls to the right, but not severely, maybe it is a alignment problem?
Old Jun 3, 2013 | 02:41 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Bob - I guess you didn't read the entire first post. I've quoted it above and highlighted the part you missed.
There is a difference between "pull" and "drift." The crown in the road (to allow for proper runoff) wil cause a slight drift while a bad alignment will cause a "pull."
Old Jun 3, 2013 | 02:42 PM
CEB's Avatar
CEB
I'd opine that there was a pothole or a curb that you didn't avoid.
Old Jun 3, 2013 | 04:36 PM
MCF's Avatar
MCF
E350
Well, if I want to get the alignment checked, any reason to take it to a dealer or indy shop or should any wheel/tire shop be sufficient?
Old Jun 3, 2013 | 05:40 PM
grane's Avatar
GLK350, SL63 AMG
I know that a tire shop with an alignment rack can check it against factory specs, check out your tire wear/rotation, etc. So at least you will know if your alignment is off or if something else is amiss.
Whether they can actually align the car is a different issue, you may have to go to the dealer. Alignments as you know should start in the rear, and then the front.
I had one MA/CT indy chain align an AMG and a Gwagen, the latter is also a 4matic, with good results. Others would not touch either nor would they balance genuine MB wheels.
Hope this helps.
GoBlando's Avatar
2012 E550
Check your tire pressure first. If one or two tires are 4lbs low, it can produce this affect. Check the gas door on your car and compare them to what the computer says.
Best method to fill tires:
1. Fill all 4 tires to be 5psi greater than advertised on the gas cap.
2. Park car on a level surface overnight.
3. Check pressure in the morning and let air out until each tire matches cold tire spec from gas cap.
4. Drive the car for a couple of minutes and store the new tire pressures
Old Jun 3, 2013 | 06:49 PM
grane's Avatar
GLK350, SL63 AMG
I had a wander to the right with the right front off 2 psi. Correcting the pressure corrected the problem. I personally run the RF tire 1 lb higher than the left and check pressures once a week on a weekly calibrated gauge/pump at the local shop. If you can rotate your tires that helps too. Maybe I missed the kind you are running?
Old Jun 3, 2013 | 09:10 PM
MCF's Avatar
MCF
E350
Thanks. The rear tires have the same pressure and the front right is actually 1psi more than the left which should make it pull to the right less.
Old Jun 3, 2013 | 09:56 PM
DG_Guy's Avatar
2010 E550, 2007 R350
Bought a 2010 E550 used about 5 months ago. It pulled to the right about 80% of the time (especially at high speed.). Took it to the dealer and had them work on the alignment. Then it pulled to the left at high speed. Took it back and it was better but it still pulls left. Under 35 mph I'm fine. At 75 MPH I'm pushing the steering wheel. Not always, but most of the time.
Old Jun 3, 2013 | 10:24 PM
mleskovar's Avatar
'17 Jaguar XF
My experience is that MB dealers are better suited to handle alignment nuances. If I'm not mistaken only front toe is fully adjustable without changing parts or part positions so what would a tire/alignment shop do anyway? The dealer may cost more....about 2X....but they have the parts and specific model expertise and you can always go back if not satisfied.
Old Jun 4, 2013 | 07:42 AM
hyperion667's Avatar
2012 CLS63
the dealer I sometimes go to has a 'risk free' alignment, menaing there is no charge just to check.......but chances are they'll find it out enough for a sale........
good luck with it
Old Jun 4, 2013 | 11:31 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Every M-B I've gotten I've taken to the dealership right away because of "alignment problems". Never fails.
Always the same answer: "M-B's are very sensitive to the crown on the roads". Roads are seemingly always "crowned" to the right. After a while I realize it's normal. Not sure why it is, either by design (which I couldn't understand) or fundamental flaw.
Old Dec 5, 2013 | 08:57 AM
Hfdafhx's Avatar
Pinto
Today had 4 wheel alignment, road force balance and brand new tires all 4 corners
2010 e350 4 matic under heavy acceleration pulls right and front end lifts quite a bit
Old Dec 5, 2013 | 11:58 AM
alanme123's Avatar
2012 E350
Pulling to the right is normal because of the crown of the road. I think the only way to adjust it is for the alignment people to compensate for that while doing the alignment. Even then it wont be perfect
