Sponsored by: CARiD
Help with tire sizes
Old Jun 10, 2013 | 06:35 PM
alanme123's Avatar
2012 E350
I called up a local shop and they recommended me 245 in front and 285 in rear for my 19 inches 8.5 and 9.5. Would this work with no issues? What sizes do you guys recommend? Also, I was thinking about TSW interlagos. Rims suggestions would also be great!
Old Jun 10, 2013 | 08:54 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Tire sizes are way more than width. The wheels (and tires) sound a bit wide. You may run into clearance issues.
Go to this link for the offset and tire size calculator to help you get the proper size wheel and tire.
Remember that the outside diameter of your new tire must be within 1% of your OE size.
Old Jun 11, 2013 | 01:01 AM
alanme123's Avatar
2012 E350
Thanks for the input CEB, I am not familiar with the tire size things, so I consider myself still a noob in this field.. I have no idea what I should be looking at for that calculator. What sizes would you recommend me to get without any clearance issues for 19 inches?
Old Jun 11, 2013 | 10:11 AM
CEB's Avatar
CEB
It depends on what you want.
Do you have staggered sizes now?
What size tires do you have now?
AWD?
Are you comfortable with wearing out tires quickly since they can't be rotated?
Are you OK with the additional cost of good quality rubber for the large, wide wheels - the larger size could cost anywhere from $50 to $200 more per tire depending on the tire you pick.
Are you OK with a significantly harsher ride of the much larger wheels (and the smaller sidewall)?
Are your roads good enough for a 19" wheel?
Why do you want the 19", very wide wheels?
These are questions you need to ask yourself. There are no wrong answers and it is OK to say "for looks" on the last question.
A quick tire size primer
19 (or 17 or 18 or whatever) is the size of the wheel diameter measured in inches from bead to bead (where the tire sits - so the actual diameter is always a hair more, but close). For modern passenger cars the sizes are always in whole inches.
The 285 (275, 255, 165 or whatever) is the width of the tire contact patch in mm - so a a 285 tire would measure roughly 285mm.
The 35 (40, 45, 50 or whatever - generally between 30 to 85 for passenger car tires) is the height of the sidewall expressed as a percentage of the width of the contact patch.
The standard size tire for a 350 is 245/45-17 . This means that the contact patch is about 245mm, the sidewall is 45% of that and it fits on a 17 inch wheel.
This means that the OE tire has an outside diameter of about 25.68 inches. Subtract the size of the wheel (17) and you are left with 8.68 inches. Divide that by 2 (because the "half" of the sidewall is on either side of the wheel and you come up with 4.34 inches - which is about 110.236mm. 45% of 245 is 110.2
To get the same outside diameter for a 19" wheel and a 285mm wide tire, you would need a 30 aspect ratio tire - a 285/30-19. That gives you a an outside diameter of 25.73 or about as close as you can get.
Let's look at the sidewall though. You've gone from a 4.34 inch sidewall to a sidewall that is 3.465 - or about an inch less.
Old Jun 11, 2013 | 02:41 PM
alanme123's Avatar
2012 E350
Thanks for your help CEB, let me answer those questions first
-Yes
-18 OEM AMG wheels
AWD?
-No, RWD
-Yes
-I am fine with better quality. Actually prefer it
-I think I will be fine with the harsher ride. I am wondering will there be a big difference going from 18 to 19?
- I believe so. I live in Irvine, So cal and i rarely see potholes here
- This is mainly for looks. Also right now I have the continental pros that came with the car and they are becoming so loud whenever I drive. I know that 19s will give the car a harsher ride, but if I get a better quality tire would that reduce the noise?? I also want the tires to be flush with the side of the car and not sticking out.
The local shop recommended the michelin supersport, but I am not sure if I even need that type of tire. It seems a little overkill for my needs. I normally just commute everyday.
I was looking at the Michelin MXV4 Primacy. Ultimately, I want it for the looks but I want to also be on the safe side. I don't want to be having any issues with clearance or rubbing. Would the 285 be way overkill in terms of width? Also with the sidewall of 3.465, would that be an issue?
Thanks for the help again!
Old Jun 11, 2013 | 04:40 PM
CEB's Avatar
CEB
As tires wear, they become louder. Will you feel a significant difference going from 18-19 inch wheels - possibly, since you are losing a half inch of sidewall.
As far as tires are concerned, you need to decide about your driving style. Will you ever drive at temps going below 40 degrees (or about 50 degrees regularly) with this car? If so, then you'll need an all-season tire. In your neck of the woods you can probably get away with a performance all season tire.
I'm actually a fan of Conti. They have a very nice DWS tire that is reasonably priced.
As far as fitting flush with the wheel well, you'll take "offset" into consideration.
Somebody else is going to have to jump in here with thoughts of rubbing with 285's
Old Jun 11, 2013 | 05:47 PM
alanme123's Avatar
2012 E350
I was originally thinking about getting 275s in the rear. Is there any fitments you would recommend for 19 inches with 8.5 in front and 9.5 at the rear?
Thanks for the help again...I heard good things about dws as well. I will look into that too
Old Jun 12, 2013 | 12:36 PM
greasykid's Avatar
2015, ML250 BlueTEC
tire size
[QUOTE=alanme123;5675413]I called up a local shop and they recommended me 245 in front and 285 in rear for my 19 inches 8.5 and 9.5. Would this work with no issues? What sizes do you guys recommend? Also, I was thinking about TSW interlagos. Rims suggestions would also be great![/QUOT
call Tirerack
