Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class How to Install Illuminated Door Sill
Step by step instructions for do-it-yourself repairs
Replacement Illuminated Door Sill Plates
2010 E63 AMG
I just purchased A CPO 2010 E63 AMG and just had the car gone over with a fine tooth comb by my detailer and it's looking sweeettt. The only thing that is nagging at me is the scuffs and scratches on the factory installed illuminated sill plates. So I called a local dealer her in Boston and asked how much replacement sills cost and they told me it's part # 212 686 2936 and they're $70 each. However, when I look up that part number on a couple of sites it says "w/o illum" so is the dealer quoting me for the regular sills?
Also, if these end up being to expensive how easy/hard is it install aftermarket ones given that I already have the wiring from the factory ones. If I decide to go OEM, how easy/hard is installation to just replace the sill and not have to do any wiring.
Thanks and looking forward to being an active part of the community here.
Nisi
Nisi
Received 4,435 Likes
'71 Pinto
EPC shows OEM illuminated left 2126800735, right 0935 – check your PM. BTW you should be posting here https://mbworld.org/forums/w212-amg-146/
2010 E63 AMG
Thanks for the info and sorry for posting in the wrong forum.
2012 E350
OEM Illuminated door sills are like $800? I also heard that you have to take apart half your car in order to install those without cutting any wires.
The aftermarket illuminated door sills usually just come with wiring and can be taken care of around $120 at a local audio shop. Those sills will only run you around $200. They look very nice too as I just got them installed in my car. I didn't have time to take pics of them yet. I don't know how they would compare to the factory ones though.
Here is the link where I got mine at.
http://www.formymercedes.com/mb_resu...l+Replacements
Again, check to make sure that these are good with your E63.
2010 E63 AMG
I'm trying to deciper how much the OEM ones are and also it looks like since I already have illuminated ones installed that it should be pretty straight forward and not require taking 1/2 the car apart.
Thanks for the info/feedback.
Door sills
Nisi
Nisi
2010 E63 AMG
I just had the car professionally detailed and the detailer did his best with the sills but between the difficulty of working with the scratches on the stainless steel section and having to worry about overheating the plastic when polishing, still looks pretty beat up.
I'll post some pictures depicting the damage/condition.
2010 E63 AMG
I've attache a picture and a zip file with high resolution image showing the damage I was referring to.
