Sponsored by: CARiD
LED Reverse Light
Old Oct 10, 2013 | 08:24 PM
Mixelplux's Avatar
E350
LED Reverse Light
Hello,
I've gone thru 2 different ebay so called Canbus "Error Free" LED reverse bulbs and nothing works. I've got a set from IJDMToys and that also threw code. Strangely the bulbs dont throw code anywhere aside from reverse. Anybody know a good set that won't throw code for reverse?
Old Oct 11, 2013 | 07:57 AM
Pewterslk320's Avatar
Pewter 2003 slk320, 2011 Black C300, 2013 C350 Loaded
Mixelplux, I am using on my C350 2013 for reverse light bulbs the following with no errors:
http://www.superbrightleds.com/morei...ed-tower/1326/
Old Oct 11, 2013 | 11:39 AM
Mixelplux's Avatar
E350
hmm however the E350 uses 921 bulb
Old Jun 8, 2014 | 08:43 AM
lightfytr's Avatar
2011 E350 Sport
Ive tried 2 different bulbs and both throw codes, has anyone else changed the reverse bulbs to leds in the w212?
Old Jun 9, 2014 | 03:19 AM
Las84's Avatar
W212
I use these ones. http://www.ebay.com/itm/2Pcs-T10-T15-High-Power-7W-SMD-LED-Back-UP-Backup-Reverse-Light-Bulb-Lamp-/400422287858?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3b0739f2&vxp=mtrNo problems and lots of light when backing upp. Tried some xenon lights but would not work properly.
Old Jun 9, 2014 | 05:19 PM
lightfytr's Avatar
2011 E350 Sport
Originally Posted by Las84
I use these ones. 2pcs T10 T15 High Power 7W SMD LED Back Up Backup Reverse Light Bulb Lamp | eBay
Thanks!
Old Jun 9, 2014 | 05:56 PM
ph350's Avatar
e350
The ones that don't throw codes have resistors on them to draw the same wattage as the stock ones. Just ask the seller what wattage the bulb dissapates or use the recommended ones.
Old Jun 9, 2014 | 07:53 PM
AudiA4Turbo22's Avatar
'03 A4 2.0 Stroker, '14 E63 S AMG, '10 E550, '10 S550, '03 C240
The 2014+ E-class has LED reverse lights, not sure if they are built in or if they use a similar connector.
Old Jan 11, 2017 | 11:23 PM
Robert Liriano's Avatar
2010 E350 Mercedes Benz(w212)
lights showing codes
Go on eBay or amazon and order error free lights. You'll stop getting msg on you E350.
