Sponsored by: CARiD
brake indicator illuminates
Old Oct 11, 2013 | 07:43 PM
i-like-typer's Avatar
W212
hi all, thanks for looking
does all W212 fit brake wear indicator illuminates? front and rear?
does indicator illuminates for brake disc wear or pads wear?
Old Oct 12, 2013 | 02:45 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Brake wear sensors detect pad wear - they are typically installed on the front pads only.
Old Oct 12, 2013 | 07:19 PM
Arrie's Avatar
Pad wear sensors are installed on front and rear but only one on each axle. If I remember correctly in my car the sensors are on the right side. There also are wiring for the sensors on the other side but the sensors are not used there.
Old Oct 13, 2013 | 09:12 AM
Nuru's Avatar
S350 BT 4MATIC
Hmm, seems kinda arrogant to not put sensors on both sides, as one cannot always guarantee even reasonably consistent wear on both sides with breaks
Old Oct 13, 2013 | 11:22 AM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
Its a cost cutting measure.
Old Oct 13, 2013 | 11:46 AM
Arrie's Avatar
I was thinking to add sensors on the left side but my pads wear really ecenly so I thought it does not need them.
I live in south summer conditions around the year so my wheels dont see spinning on slippery roads. In winter states pad wear could be a lot more uneven as slippery conditions cause the wheel spin that the brakes then control thru the ESP (called ESC in my car).
The sensors are cheap and very easy to add so if the conditions cause uneven pad wear adding the sensors on the left side is an easy and low cost way to make sure fast pad wear does not cause any surprises.
