Sponsored by: CARiD
Fluid flush
Old Nov 23, 2013 | 05:52 PM
lyjw88's Avatar
C63s ED1 Coupe
Fluid flush
I just dropped off my car for B0 service at 38k miles and the dealer recommended me to do Brake and Tranny fluid flush while at it.
And it will cost me $1200 all together.
Should I do those flushes at this point or wait?
Old Nov 23, 2013 | 06:31 PM
Benzbias's Avatar
CL550 & CL55 AMG
Absolutely not necessary - unless you have been at the speedway/track.
Old Nov 23, 2013 | 09:59 PM
xolinlevh's Avatar
2011 E550 4Matic
good to hear this, im due for my B0 soon as well as the mentioned flush, and a transmission service. good to know they arent 'required'
Old Nov 23, 2013 | 10:11 PM
Smalone01's Avatar
E55 Wagon, E550 Conv
Yeah it should be done. Trans fluid is due at 40k and brake fluid is due every 20k or 30k.
Old Nov 23, 2013 | 11:24 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
Transmission fluid is every 39k. Brakes every 2 years regardless of mileage.
Old Nov 24, 2013 | 02:26 PM
lyjw88's Avatar
C63s ED1 Coupe
I decided to do B0 for now and take it to a reputable indy shop to do the flush at a lower cost.
Old Nov 24, 2013 | 03:55 PM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
Didn't the Transmission Flush go up from 40k to 70k?
Brake fluid is every 20k or 2 years. I've been doing that, but I do about 17.5k a year, mostly highway (less braking) so not sure if it's really needed every 20k?
Old Nov 24, 2013 | 04:30 PM
Benzbias's Avatar
CL550 & CL55 AMG
Prudent maintainance
1st xmission (fluid/filters) about 60K - gets rid of the break in wear and tear (filings) after that no need! Important aspect is to ensure that it is a full drain as any residual fluid will contaminate the new.
Brake fluid about every 2 years (can be longer) under normal driving conditions
the big one and most important is of course regular oil changes with a filter replacement at the same time - car engine will run forever!
Old Nov 24, 2013 | 05:15 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
The W212 Service guide calls for a brake fluid flush at 20K miles or 2 years - that's the same as the B service interval.
The interval for transmission fluid & filter is shown as 4 years or 40K miles. You're pretty close at 38K.
