2013 w212 switching 17" to 18"
W212 2013 E250 CGI
My previous wheel was a avant-garde alloy, but nw i switched to mandrus 18" front 8.5 and rear 9.5 offset as recommended 265/30 rear and 255/40, facing probs wit da tpms on da display, will da problem go if i replace my 17" tpms sensor to 18" ???
2014 E350 Wagon
If the TPMS sensors of the original wheel are compatible with the new wheel then yeah, it should fix your problem. The sensors don't care what wheel they're in as long as they can mount and seal up fine.
Learn more about it at tirerack.com
http://www.tirerack.com/tires/tirete...sp?&techid=152
Received 3,425 Likes
2012 CLS63
I have a set of Mandrus (Manheim) and a set of Vossens(CV1's).......both great wheels......I am hooked on HRE now so I don't use them much anymore, but still good wheels for the price......
can't go wrong with either one IMO........
good luck OP.......
and in case you are from a far off land, I'm sorry some member is making fun of the way you type.......
again, good luck OP
Vossen CV1 on my old E63 (19's)
Mandrus Manheim on my 550 (18's)
good luck OP.......
again, good luck OP
W212 2013 E250 CGI
I have a set of Mandrus (Manheim) and a set of Vossens(CV1's).......both great wheels......I am hooked on HRE now so I don't use them much anymore, but still good wheels for the price...... can't go wrong with either one IMO........ good luck OP....... and in case you are from a far off land, I'm sorry some member is making fun of the way you type....... again, good luck OP Vossen CV1 on my old E63 (19's) Mandrus Manheim on my 550 (18's)
good luck OP.......
again, good luck OP
good luck OP.......
again, good luck OP
The shine on your E550 is incredible! Clay bar or gloss??
2012 CLS63
bar
