Ride quality lowered
2010 E350 Sport
For those that have lowered their w212, how is the ride quality compared to stock? and what size tires do you have? I was going to do 19s and lower with
H&R Springs.
Feedback is much appreciated
Thank you
H&R Springs.
Thank you
I've just lowered mine with Vogtland 40mm and the ride is ok. Rides over small bumps exactly like it was stock. The bigger bumps you can feel are more sharp or you can feel the spring is stiffer. Spring rate is higher than stock but I feel the stock shocks can't compensate for the higher spring rate so it gives a slight single bounce effect over larger bumps. Hard for me to tell my setup has 65000 miles on it. I will probably change out the struts and shocks for the Bilstein HDs. There is a definite difference from stock.
2010 E350 Sport
2010 E350 Sport
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Hello.
Lowered w/ H&Rs and used to run 19 without any problems. Pic of my ride in my sig and link of more pics below the pic.
Can't imagine running 20s as I don't think they would fit without rubbing.
Ride is fine and not much more different than stock.
Currently on 18s as the 19s were getting chewed up in Los Angeles.
2010 E350 Sport
Hello.
Not sure, but Eibach might give you that "rake" look. Lower in the front and not still a little high in the back. But please do your own research. I think read somewhere here that somebody had that case. My BMW is on Eibach and it has that "rake" look. Good luck...
