Sponsored by: CARiD
another 20 inch tire and offset question
Old Jan 3, 2014 | 09:36 PM
iErickS's Avatar
2010 GL450 / 2010 E350 P2, Black top, Pano
Im looking at getting some 20s. Shop is telling me to go 20x8.5 with 34et up front and 20x10 with 40et in the rear.
My question is, won't this stick out too much? I don't know if I want to lower it yet. Also saying 245/35 front and 275/30 rear. I've read from the gurus here that the front won't work but with that offset could it have a chance? I don't like how a 235 wouldn't extend to the outer lip of the rim.
Old Jan 4, 2014 | 10:51 AM
EGray@Germain's Avatar
2020 AMG C63s
I'm running 245/30/20 front and was with a 285/25/20 rear that was with a falken 452's. I tried using Hankook Ventus V12 285/30/20 on the rears since the 452's falken are discontinued. They rub in the inner back liner..so a 275/30/20 will fit the best.
Hope this answers your questions.
Thanks,
Eric
Old Jan 5, 2014 | 03:23 AM
iErickS's Avatar
Thanks. I ended going with 34et offset up front with 235/35/20 and in back 40et offset with 275/30/20s.
The wheels in the back look like they're sticking out. I'm not used to it. I'm kinda wish they tucked in a little more.
Thanks for your reply and all the replies on all the old threads. They helped out tremendously.
Now I just have to find someone in Sacramento to lower the car.
Old Jan 8, 2014 | 08:21 AM
E350rulz's Avatar
2014 E350 w/ every option :)
What rims are those ?
Old Jan 8, 2014 | 08:44 AM
bigigg's Avatar
14' CLS550
That's perfect fitment/offset.. you'll see when you lower the car it will look great!
Old Jan 8, 2014 | 11:26 PM
iErickS's Avatar
The rim purchase was a last ditch effort by my wife to keep the car. I switch cars pretty often. I can't even last a 36 month lease.
So I looked on Craigslist and called around. These niche milans were in stock and in the offsets to match the car so I bought them.
You're right, it looks like the wheels are sticking out past flush but the car has settled a bit and it's looks great
even without being lowered. The wheels are flush up top but as the wheels cambers out it sticks out. It looks good tho.
I'm still on the fence about keeping it.
I knew when I bought it I should have gone with a e550.
Click image for larger version
Old Jan 9, 2014 | 12:31 AM
RobbieRob's Avatar
18'Porsche GT3, 16' Ram 3500 mega diesel,30' Model A Ratrod, 17' E43
If you lower you will rub crazy, even if you hit a big dip and bottom out not lowered, you're going to rub in the rear. The rear offset on a 10" wheel should have been around -48, front should be fine, close, but fine.
Old Jan 9, 2014 | 03:52 AM
iErickS's Avatar
I'm running front:235x35x20 on a 8.5 wide wheel with -35 offset, rear is: 275x30x20 on a 9.5 wide wheel with the same -35 offset. Front and rear is real flush with this setup, -38 or -40 would probably be better for me since I am lowered quite a bit, but I still don't rub. Do a search in this forum on,"20" wheels", plenty of posts and answers out there.
Read more: https://mbworld.org/forums/e-class-w...#ixzz2ptCLWi5e
I agree that I will rub but I read one of your old posts and your set up looks as aggressive and you don't rub?
Old Jan 9, 2014 | 07:26 AM
bigigg's Avatar
14' CLS550
Sorry, I disagree.. I had same exact setup in the rear, lowered on Vogtland springs. No rubbing issues at all.
Old Jan 9, 2014 | 11:10 AM
RobbieRob's Avatar
I am running a(rear) 9.5" wheel with -35 offset, same tire as you. That is 1/2" wider than my setup, but your offset is only 5mm difference(for reference, 15mm=1/2"+-), and I am as close to rubbing as it gets. I can barely slide a piece of paper between my wheel and wheel well. Mine is aggressive but still flush, yours look like they stick out a little.
Old Jan 9, 2014 | 11:14 AM
RobbieRob's Avatar
Talking
Really, same offset? You can be the one to tell the OP to go ahead and lower, that he will not rub. I wouldn't even think twice, its going to rub. Give him a phone number for a good bodyshop for repairs....lol/jk
Old Jan 9, 2014 | 11:32 AM
bigigg's Avatar
14' CLS550
Member..Juliana21 has same setup, he will tell you the same thing. a 275/30 on a 10" wide wheel is slightly stretched. most likely a 285 lowered would rub at that offset
Old Jan 9, 2014 | 11:54 AM
bigigg's Avatar
14' CLS550
1/2" is about 13mm(difference bewtween 9.5 and 10" wheel.. split the diffrence is 6.5mm, 40et brings it in 5mm. soo the 40et on a 10" setup sticks out 1.5mm aprox past yours, and 11.5mm closer to suspension.
Old Jan 9, 2014 | 12:36 PM
iErickS's Avatar
Smile
1/2" is about 13mm(difference bewtween 9.5 and 10" wheel.. split the diffrence is 6.5mm, 40et brings it in 5mm. soo his setup sticks out 1.5mm aprox past yours, and 11.5mm closer to suspension.
That's what I was thinking. Robbierob's wheel is half inch as wide but offset pushes out. We're pretty close to the same.
The wheels does however stick out a little toward the bottom. The top of the tire does would not tuck if I were to slam it, which I would never do anyway. I would have liked it about half t inch in but the next offset in a 20x10 would have been in the 50s et.
Everyone that has seen it, thinks it looks good. I'm still not sure.
Thanks for the comments and help guys.
Erick
Old Jan 9, 2014 | 01:10 PM
RobbieRob's Avatar
Yeah, I wish mine had a small amount of offset more in the rear also, instead of -35, maybe -38ish. - 48/-50 would be perfect for you. The way mine is doesn't rub except on off camber driveways, pulling in on an angle ,I get a tiny rub. Looks good the way it is, but over time you will want to lower(we're just programmed that way,lol). Good luck with whatever you do.
Old Jan 9, 2014 | 01:29 PM
RobbieRob's Avatar
Quote from Juliana21:
Wheels:
20 x 8.5 F et34 235/35
20 x 10 R et40 275/30
NO Rubbing!!! not once .
This is what Juliana21 is running, same setup. You are right my friend, I honestly would not think that would be the case. I guess because the tire is stretched more on the 10" wheel.
Old Jan 9, 2014 | 08:11 PM
iErickS's Avatar
Here's more pics of my rear wheel sticking out. Maybe the 40et offset by niche isn't accurate.
Old Jan 10, 2014 | 04:54 PM
justana's Avatar
2011 E350 P1 sport package with panoroof
Are you going to lower the car? I think u should. I did with eibach, and love the ride... I dont know how to put picture, but you could see it on my profile for actual. It doesn't rub at all.... Good luck...
Old Jan 10, 2014 | 06:02 PM
iErickS's Avatar
Yeah, I'm strongly considering it.
What size wheels and offsets do you have?
Old Jan 11, 2014 | 07:15 AM
bigigg's Avatar
14' CLS550
you say "sticking out" yes the wheel is very slightly maybe 5mm.. but picture the car lowered and the tire tucked in the fender. It would look perfect!
Old Jan 12, 2014 | 11:30 PM
justana's Avatar
Im not sure about the offset, but size are 20x9 front, 20x10 rear. They set up for my car after i told them what i want.
Attached Thumbnails another 20 inch tire and offset question-img_2803.jpg   another 20 inch tire and offset question-img_2806.jpg   another 20 inch tire and offset question-img_2828.jpg
Old Jan 13, 2014 | 06:42 AM
bigigg's Avatar
14' CLS550
^ looks like a 45et rear, what are you lowered with? looks good
Old Jan 13, 2014 | 10:57 AM
justana's Avatar
Thank you. I decided to get eibach instead of other brand. Its still comfort. In fact, I went to mountain with 4 persons and full on the trunk yesterday. It didn't rub at all.... My set up tires are 235/35/20 front, 255/35/20 rear. If I put bigger tires, its gonna be rubbing for sure.
Old Jan 13, 2014 | 11:03 AM
justana's Avatar
Here's the look when my family inside the car.....😋
Old Jan 13, 2014 | 11:15 AM
bigigg's Avatar
14' CLS550
Ok,i got it now.. 4 people in car and loaded trunk.. I was going to say that drop is more than what springs will do.
