Very concerned about the 4matic transmission
I need your inputs. I did a pre-trade for a new Mercedes but I just can't pull the triga on a new car because I am reading the issues about the 7 speed transmission having to be replaced whenever the diff goes bad on the 4 matic.
I am very interested on buying a E550 sedan 4-matic but just the idea of having to replace the whole 7 speed transmission because of the Diff going bad makes me worry. I heard this topic about the GLK 4matic breaking the diff and having to replace the whole thing (transmission and diff) because the diff is inside.
Is this the same issue on the cLA 45 AMG? If this is an issue I might turn around and look for a RWD car.
All the reports and complaints I see are due to the internal transfer case on 7G Tronic 4MATIC.
The CLA won't have that problem - it's a FWD-based car. Totally different transmission and AWD set up. Not saying it won't have problems....but they won't be the same as the 7G Tronic 4MATIC on the RWD-based sedans and SUVs.
Transfer case is a part of the old fashioned 4-wheel drive that does not have the center differential. These 4-wheel drive vehicles are not supposed to be operated with 4-wheel drive engaged when driving on dry pavement where tire grip is good. 4-wheel drive is meant to be used on slippery surfaces where the tires don't have the best grip.
All Wheel Drive cars have center differential meaning that the front and rear axles are allowed to turn at different speeds as the center differential allows for this without stressing the power transmission parts too much. Well, MB may have a little problem here as they don't want you to have the staggered tires with the 4Matic obviously because this would cause a speed difference between the axles and wear on the "primitive" center differential lock, which I believe is a simple spring loaded "disk brake".
Will see if the peace and silence will last.
These are car forums , guys who ask car questions, some of which you may not like but they are asking because there is genuine interest. Not get another car.
You can call it transfer case/center diff.
MB basically mated this unit into the 7G box and sell them as one for $7xxx. Makes it easier for dealer save time to "swap" things out.
I would have posted the same thing when I first saw this thread but I chose to ignore the thread instead.
Now that we are all being honest.
This is a DUMB thread.
This also shows that any tire diameter difference between the axles will cause movement on this clutch that wears it over time.
It also says that these 4Matic cars are basically FWD cars with a "helper drive" at the rear wheels.
And now I see why Audi Quattro drive is so much better.
P.S. Found below Youtube and it really explain how the 4Matic powers the rear axle when needed, i.e. it is a FWD car with the RWD enabled when needed. This does not mean it is something bad. It just means it is a FWD car on good grip surfaces and here is where the staggered tire setup is a problem. With speed difference between the axles the system engages the rear axle, which then makes parts to wear as something has the give. Mostly this would probably show in very fast tire wear.
The slightly older versions, like I've had all had open diffs and utilized the ABS wheel speed sensors and brake loading to balance slipping wheels.
I have a recollection that the current E has something similar to what you posted but in reverse whereas the front wheels are enabled when the rears are slipping.
Further, if you have a system that use brakes for "locks" like Audi Quattro system does you really need the center differential for true AWD functionality. By what the video shows MB 4Matic is NOT an AWD system as world knows these three letters mean. It is far from it.
C and above have the traditional Rear drive based 4Matic like the picture below
