keyless-go
I'm currently driving 11 gl350 bluetec with P2 option so I know i can tell if it has keyless-go however, I'm confused with e350...
please see attached photo. there are small black buttons on door handles so I can lock my gl350 as it has P2 (keyless-go) system however I'm not sure if e350 is the same way or not... as some dealers describes in their ad that it comes with keyless-go but as you can see from attached photo, there is no button...
can someone tell me how I can tell if e350 has keyless-go system or not besides the push start button? (some pics don't have push start button shown though)
The black or dark red window is for the infrared signal as you can use the key FOB to open or close all windows at the same time.
Also in pics looking for the button for push start if they show that view.
Best advice I got - you can lock he door with a hip check if your hands are full.
I might be wrong, but my recollection is that the button is for closing the sunroof and windows while locking.
There is a slight square indent on the OUTSIDE of the handle that is used to operate the windows/sunroof with keeyless-Go.
Aside from the ways that drsaab mentioned, an E-Class (2010-2013) car equipped with keyless-Go will have chrome on top of the handle. (I dont know if that changed for 2014).
For the all window operation the sensor is the dark smaller rectangular area. It is the infra red sensor to read signal from the KEY-FOB. The bigger indentation is where the touch sensor is located at. It is true that touching anywhere on the handle should lock the doors but it is more sensitive on that shallow indentation area.
I said "to operate the windows/sunroof with keeyless-Go"
Press the small square indent and hold, all your windows will go up and the sunroof will close.
If your car doesn't respond at the slightest touch anywhere on the handle perhaps you should get it checked. I can close mine by touching anywhere on the handle with any part of my body even with gloves or my butt with heavy jeans on.
+1 I give my handle a light tap with my knuckle as I walk away. Works every single time.
