A22240100007X21 wheels will they fit 2014 E class ?
1 Post
2014 E350 w/ every option :)
Hi,
I know there are lots of "will they fit threads" but I dont want to hijack anyones so I am starting my own.
I have a 2014 E350 with the stock AMG 18x8.5 wheels. I want something more agressive for the summer.
I like these 19" design on the Sclass.. A22240100007X21
You can see them here.
http://www.mb-configurator.net/mba/w...lgrp=933007030
My question is will this fit .. I dont plan on lowering the car.. just want to know if I use those wheels will it fit and with what tire sizes.
W222 (new S-class) wheels are 8.5" et36 front and 9.5" et43 (or so) rear. You can use front at all 4 corners (square) or staggered, your choise. Tires could be 245/35-19 & 275/30-19, or (my preference) 255/35-19 & 285/30-19 (if staggered). Do not get concerned yourself with technical issues, pictures, diagrams, centerlines, etc. All above will fit with zero issues. The only issue I see is price (at least initially) of those W222 wheels.
1 Post
ok so I have some Vorsteiner on order.. FF101's... they asked if I want to do the following staggered setup..
Front
245x35x19 8.5 ET40 circum. 2057mm (81")
Back
285x30x19 10 ET45 circum 2057mm (81")
@threeMBs .. I know this is close to your suggestion 255/35-19 & 285/30-19 ... but with 245 front and 285 I can keep the overall circumference the same F/B.
Any comments from the guru's here ?
Front
Back
14' CLS550
What kind of comment are you looking for? Another member to say "yes they fit". ThreeMBs gave you great advice, the order you put in with Vorsteiner is fine, good specs. Dont forget to post pics.
1 Post
But I also know from the MB manual... the E63 is using what theeMBs said. so maybe I'll stick with that..
E 63 AMG S-MODEL 4MATIC
Summer tires
R19
Tires Alloy wheels
FA: 255/35 ZR19 (96 Y) XL5
RA: 285/30 ZR19 (98 Y)XL2, 5
FA: 9.0 J x 19 H2
Wheel offset: 1.46 in (37 mm)
RA: 9.5 J x 19 H2
Wheel offset: 2.05 in (52 mm)
Summer tires
R19
Tires Alloy wheels
FA: 9.0 J x 19 H2
RA: 9.5 J x 19 H2
Summer tires
R19
Tires Alloy wheels
FA: 9.0 J x 19 H2
RA: 9.5 J x 19 H2
Summer tires
R19
Tires Alloy wheels
FA: 9.0 J x 19 H2
RA: 9.5 J x 19 H2
14' CLS550
There is nothing wrong with adding a little more meat to the front tires. My only concern is if you plan on lowering, that 255 with a 40et might be too close to fender edge. Try it out
1 Post
ok thanks.. will go for more meat as I dont plan on lowering it..
I have been waiting to see all winter if anyone with a AMG or AMGS put anything for sale up here in Toronto.. nada.. so will go with the Vorsteiner.
Will take some pics after.. for sure.. (its gonna be 3-4 weeks tho).
I just got 19 x 8.5 square with 245/35/19 ET 45 and its a great ride.
255 will give you a little more meat for rim protection, but also less fuel economy since the standard tire is a 245 width.
The true + 1 size from the factory 245/40/18 is 245/35/19 to keep the speedometer the same I believe. The 255 will be off by 1mph at 60mph so not a big deal either.
1 Post
yea.. I'm just thinking that 245/85 in the back wont look as good as 255/285 ... might make the front look too skinny... lets see I think I will go for the staggered setup.. I have time until they come in to decide on the tires.
