Will these wheels fit my 2010 Mercedes E350 (w212)
Old 03-13-2014, 09:50 AM
lirimlokaj's Avatar
Mercedes E350 (W212)
Hello MB fans
I found some cool wheels on Ebay, but Im nor sure if they will fit my car
I drive a Mercedes E350 2010 (w212)
Here is the info:
Size: FRONT 20X8.5 REAR 20X10
Bolt Pattern: 5x112
Offset: 35
Tire Package: Front 245x35x20 Rear 275x30x20
I appriciate all answers, thank you
Old 03-13-2014, 12:13 PM
lirimlokaj's Avatar
Here is a picture of how the wheels look like
Old 03-13-2014, 12:49 PM
Las84's Avatar
W212
Dont quote me but 245/35 may be to big.
I have 245/30 with offset 35 and it isnt much rom to the plate for the shock absorber. As said I may be wrong but have read many places that this size will rub.
The back tires are good. Im on 295/25 with no rub or anything and cant se why they wouldnt fit. Maby a spacer to get the rim out abit for flush fitment.
You could also take a quick search. There are many threads with this topic.
Good luck.
Old 03-13-2014, 03:57 PM
eNNCity's Avatar
2013 E350
I don't understand how you guys run anything less than a 35 profile tire... Potholes will be sure to wreck your wheels without the extra sidewall!
Old 03-13-2014, 05:15 PM
Las84's Avatar
W212
Its actually simple. Just dont hit them.
Drive abit more careful and sometimes watch the deck for about 1 sec to see the condition of the road. And if I do hit one I just get a new rim and tire.
Sorry for the OT.
Old 03-13-2014, 07:39 PM
LasVegasMike's Avatar
2011 E350 Sedan
Here is a cool site to compare what a new wheel will fit compared to your current setup:
http://www.rimsntires.com/specspro.jsp
It will give you measurements you can use to see if they will fit or not.
Old 03-14-2014, 07:09 AM
bigigg's Avatar
14' CLS550
Front wheel is perfect if you run a 235/35.. 245/40 will rub on spring plate.
Rear wheel offset is to low, I'd recommend nothing lower than a 40et for a 10" wide wheel.
But, if you don't plan on lowering the car you will be fine.. Its harder to tell the wheel sticks out passed fender when the fender edge is 3" higher than the tire. In the end its your call, me personally I like flush fitment. good luck
Old 03-16-2014, 11:49 PM
juliana21's Avatar
13 E350 4MATIC
Flush Fitment
20x8.5 et34 235/35
20x10 et 40 275/30
Old 03-21-2014, 07:51 AM
lirimlokaj's Avatar
I this car lowered?
Old 03-21-2014, 08:08 AM
juliana21's Avatar
13 E350 4MATIC
Yes, 1.5in F & R
Old 03-24-2014, 09:28 PM
BozzMazzi's Avatar
2012 S550 4M Diamond White. 2012 E350 4M Matte Blue, 2013 C300 4M White
If the OP would allow, I have a similar question that came up as I read this post. I have a 2012 E350 4Matic with 20x9 38 offset wheels on order and can't figure out if I should go 225/35/20 or 235/35/30. The car will be lowered on Vogtlands shortly. Thanks in advance.
Old 03-24-2014, 11:30 PM
drsaab's Avatar
I am not an expert, but I have 245/35/19 and I think a 225 width on a 20" will look real Skinny. The factory width is 245 so The true match is a 245/30/20 but that leaves minimal rim protection from the tire, here is a pic of a 245/35/19....
Will these wheels fit my 2010 Mercedes E350 (w212)-a0e3b376-aa05-4c05-a3b4-16a1ea68d777_zpscrsqvd7j.jpg
Old 03-25-2014, 01:36 AM
juliana21's Avatar
13 E350 4MATIC
The set I just picked up is 20x9 et 38 Front with 235/35 same tire set up
I have now...No rubbing issues. if that's what you were worried about.
Old 03-25-2014, 01:46 AM
JoelE55's Avatar
07 E63 AMG / 07 C230 / 14 E350
Originally Posted by juliana21
Yes, 1.5in F & R
What are you using? Spring or Coil Over?
Old 03-25-2014, 02:25 AM
juliana21's Avatar
13 E350 4MATIC
Vogtland Springs. Very good ride quality. I always used H & R and it rides nice as well. IMO, Vogtland's ride quality is not to far off from stock set up.
Old 03-25-2014, 12:55 PM
onemurphy24's Avatar
2010 E550 and 2006 C230 Sport
I like the way that car sits!
Old 03-25-2014, 07:47 PM
BozzMazzi's Avatar
That's perfect. I wanted to make sure I had at least a 35 sidewall but didn't want to go skinny on the width.
Car looks great BTW.
Old 03-25-2014, 07:52 PM
BozzMazzi's Avatar
You're right, rim protection would be a problem with a 30 sidewall and a 225 stretch would give me a more "stanced" look than I want.
Funny thing about rim protection, today I hit a small pothole with my 19"s and got a slight bend. Now I'll be even more paranoid about the 20"s.
Old 03-26-2014, 02:06 PM
juliana21's Avatar
13 E350 4MATIC
Thank you, what wheels are you putting on?
Old 03-26-2014, 06:54 PM
BozzMazzi's Avatar
Work Gnosis CV201. The black wheels in the signature are 19" Volk TE37s (for reference).
Attached Thumbnails Will these wheels fit my 2010 Mercedes E350 (w212)-photo.jpg
Old 08-10-2016, 11:19 PM
MiLi's Avatar
2006 Mercedes e350 4 Matic
Hello
what's the name of this wheels
Old 08-13-2016, 12:21 PM
ElisTwoCents's Avatar
2015 E-Class
I think they are the Vossen VVS CVT....I have seen a similar wheel on eBay (cheap knockoff) for like 680 for the set but nowhere near the quality perhaps of Vossen i.e. Due to the structural differences in casting/manufacturing they might be more prone to dings/dents
Quick Reply: Will these wheels fit my 2010 Mercedes E350 (w212)
