I washed my E350BT Engine today....
I sprayed some degreaser solution on the engine and underside of the hood and washed it off with my garden hose and the engine now looks like new!
The Green-X Degreaser is sold in Walmart for under $5.00 while the BMW Engine Cleaner/Degreaser costs $12.00! I'd stay with the Green-X which works just fine.
The worst areas were just below the hood and on top of the engine cover and around the sides.
But the cloth did not get dirty as all grease stains were already removed by the degreaser and water spray.
Wiping with the cloth was to speed up the drying of the engine bay.
I've often washed the engine bays of my last two cars (BMW 335d / ML350BT). That was the BMW degreaser I used when I had the 335d.
I have used high pressure water to clean off the degreaser on my last two vehicles without any ill effects.
The reason I didn't use it this time is my high pressure power wash pump broke down over the last winter as I forgot to store it indoor and the cold winder caused it to leak and malfunction.
If you're using a power washer make sure you hold the hose approximately 30" away so as not to cause any damage or forced water into areas its not supposed to reach!!!
Last edited by DC-IT; Jun 15, 2014 at 09:42 PM. Reason: Typo by tablet's auto-correct!
BTW, after I cleaned the engine bay I noticed the plastic catch that fasten the air intake from the front grill to the engine cover was broken!
So this morning I drop by my M-B dealer and the SA called the shop foreman to check the problem.
He explained that this is quite common and is a design flaw as during cold season the plastic hardens and when you remove the air intake duck sometimes the catch breaks off.
He ordered a replacement for me.
If I had not clean my engine bay I wouldn't notice this was broken!
Since I only service my E at this dealership they gladly replace it for me FOC.
Note: Under the Engine Cover the engine was only slightly dusty so I only brushed off the dust and here's what it looks like.
I asked him, since I'm a high mileage driver (40K Miles in one year), how long can I expect to keep my E.
He said do not neglect the regular maintenance like oil and filter change and the diesel will out last the gas engine.
He has a neighbour with a 2007 E320CDI with over 500,000 KM and it's still running without any issues.
I too have the Bluetec. I am very excited as I have also heard that it will drive forever if taken care of. Not to mention, the gas mileage!
