Rattling noise on morning startup
hello everyone! i would like to state that this is my 1st visit/post in this magnificent website so i'm doing anything wrong please be glad to state it
so i had this problem like since like 6 months (when my baby reached 140000 km...i know its a lot )
i always hear a rattling noise on morning startup for 4-9 seconds and it just dissapears
i would like to mention that something terrible happened to the injectors at 60000 km and got replaced by brand new 2013 model ones (w212) and damn they were expensive
this question migh've been answered somewhere but i feel like my case is a bit different so....an answer would be really appreciated
Note:when i leave it on 2nd key position (before start-up) for like 5-10 seconds it doesn't do that noise so...i'm concerned that the injectors might've been misplaced the whole time
i also forgot to mention when i was tailgating it with my dad's car i noticed that when he puts down the throttle it just throws a lot of black smoke from the exhaust (a bit noticable)
is it related to the injectors? a mechanic said that judging from it's milage it's very normal but i'm concerned
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Most of the members here are from the US so for us to help you, you'll have to give us more information about your car such as the engine and transmission.
oh well...a quick timing chain check doesn't hurt right?
As far as I know, the timing chain noise applies to gas engines. Additionally, the timing chain would make noise regardless of how long you leave the car in the accessory position.
I think you need to look for an ignition (i.e. glow plug) issue that is the root cause - even if it a timing belt/chain noise.
The 250 diesel in the US is brand new for 2014 and is quite a bit different from the Euro version. Emission and other regulatory requirements make the engine produce less HP (195 - down from 204) and I doubt that anyone has nearly the miles you have. The older diesel in the US was the 350 which - being a V6 - is a completely different engine.
had my doubts previously but i just checked the E250 fuel filtre and yes it 's filled with "water"...did the injectors went rusty again? i hate to spend another 180000 DZA (almost 1700 euros) on a new set ;(
thanks for the info BTW
2011 ML350 Blueteck (Sold); 2014 E350 Wagon, Sport, Indigo Blue (Sold); 2021 GLC300, 2022 BMW X5
They had to replace a chain tensioner or gear I believe. They kept saying the timing chain stretched and when I asked they finally responded around a gear failure.
Just figured I'd let you know it could be that as well.
2015 E250 BT 4M
The North American version was first introduced in the 2013 GLK250, followed a year later in the 2014 E250BT. The differences between the Euro E250BT and North American version are less than you might imagine. The latter uses Bosch injectors to cope with North America's lower quality diesel fuel and a differently programmed ECM, while the Euro versions had problematic Delphi injectors.
However, all versions (except front wheel drive sideways engine configuration) suffer from one potential headache and that is the rear mounted timing gear. This arrangement was required to meet Euro pedestrian safety standards, to keep a lower engine profile at the front of the engine bay. If any timing chain issues arise with the OM 651, the engine must be removed from the car for adjustments and/or repairs.
The OM 651 4 cylinder diesel was introduced in Europe in October 2008. It is produced in about 11 different versions for world-wide use.
anyways...i think it's not the timing chain,it's my fuel pump.
reason to put it in suspicios is that it makes a bit of noise in the back,noticed it when i started it and did a quick check to rear passanger-side tire.
she might not give a good compression,also if i left the key on the 2nd ignition position (before start) for 30 seconds and started it...THE NOISE IS GONE!
my guess is that since the fuel pump is worn-out the diesel might not reach the injectors properly so...i'll remove it and have a look
2012 S350 Bluetec 4Matic, Diamond White, P2
Black Smoke from a diesel is a good thing. No worries there. The rattling you hear at startup could be just normal valvetrain noises. I am thinking more like something the hydraulic lifters taking a bit longer to charge with oil. That would certainly explain why it does not happen if you wait a few seconds, as it give the oil pump a chance to get the oil moving. Before "fixing" anything, I would try a heavier weight oil and see if that reduces the noises you hear.
it's a bit noticable compared to other E250s i've seen on the street...you can't see it on idle or stationary high revs but on hard accelerations on the highway you can notice it
isn't it belt-operated? i mean the oil pump if it's electric then i guess i should try probably after a month because yesterday i changed the oil...i'm a bit worried about the injectors due to the fact they're Delphi and DerekACS stated they're not suitable for low-quality Diesel
