Bought 2014 E350 Sport compared to my 2012
(but then again I am biased as my wife has a W211
Move 2 tx.. for 650k ill custom build you a house and a garage big enough that's hard to fill
Regards,
Don
http://www.fueleconomy.gov/feg/Find....32087&id=33551
OP, maybe you have 2011 model?
The downside of *** is the extra load placed on the battery and the starter, both of which will likely suffer from a shorter operating life. For these reasons, I'm glad that my E350BT does not have ***. Of course, you can disengage the "Eco" mode in your 2014 E350 by pressing the switch !
As others have pointed out, the V6 gas engines and transmissions in the 2012 and 2014 E350 are identical.
The gas engined V6 E350 can't come close to that range. Both cars have the same size fuel tank, 80 L.
Enjoy your Benz-tesla
Mine has that problem when I picked that up, about early April, I sent it to the dealer and they gave me a firmware update on trans and solved all the problem
My car has the same problem and my dealer Motor Werks in barrington say's it is normal. What dealer did you bring it to to get a firmware update? I would appreciate the help thanks.
MB in Germany has estimated a 7-10% reduction in in-city fuel use.
You can archive similar savings by turning your engine off at known long stop lights and similar delays. You can expect to see savings when you shut your engine off for two minutes or more.
