Lower LED fog light issue
Thanks in advance....
This light should come ON automatically if you have enabled it in the cluster menu. At daytime when head lights are off you should have these DRLs lit up only at the front end of the car.
DRLs are designed to make the car front visible at daylight conditions and there should not be anything else lit up a daylight.
Things change when it gets dark enough for the head lights come on from the photo cell. This will still keep the DRLs on but on half power.
Anyway....I kinda figured out those must be DRL related because I have seen other MERC including C and E are all having the lower lights on without the head lights on day time....however, I tried this morning, my headlight are on along with the lower LED...for the whole time I drive to work. I can have both ON or OFF..but cannot get to the lower DRL on by itself without the headlights are on....weird.
Thanks for all the help....
You do have a fog light in the rear on driver side only. That is what the button next to the light dial is for. If you had a luxury trim car you would have four round lights in front of the car in place of the two hockey sticks. Two of those four round lights would be fog lights and the other two DRLs. In a car like this you also have two buttons around the light dial for the fog lights. One for front and one for rear.
Your hockey stick DRLs should be on alone at daylight if you have them enabled in the cluster menu and your light dial is on AUTO. If not there is a problem with the car.
Thank you....this is resolved.
