E350 DC-AC plugin. Max watts?
I searched the MB site and cannot find an answer.
I got the MB optional DC-AC plugin where you can use
your 110V AC items.
What is the max wattage that can handle?
Supporting only 150 watts makes it all but useless really, as that equals a bit less than 1.5 amps @ 110V. There's an DC/AC inverter in there somewhere. Fine for charging a phone, laptop, or tablet, probably not so for even a small compressor.
Would take more than an inverter change; wiring, the outlet itself too, before you could pull any sizeable load through it.
Isn't the outlet a simple two prong? I didn't look at mine very close.
Dan
I'm also curious to take it apart as, per the technical docs, there's apparently something inside it which tells the eco start/stop NOT to engage. This might lead to being able to permanently disable eco start/stop for those who don't like it. If it's a microswitch, it'd be as simple as plugging in a cheater plug into the outlet.
I'm an electrical engineer (my original schooling anyway) and, while confident in my abilities, I would be a bit reserved about changing out such components while the car is so new and still under warranty. Beyond that... who knows. The start/stop idea is interesting. In my current ride, I just hit the defeat button on the dash when I start the engine (...unless I forget and then do it on the fly).
I much prefer to charge my phone via the 115V outlet facing the back seat. Smaller hookup, out of the way. And it uses the charger I take into the hotel at night if necessary.
I had an AC outlet in a previous car and tried to use it for my coffee maker during a power outage....bad idea...blew the fuse....I would have been a hero that morning if it worked ;-)
Slow (only 150 watts), but they do work.
12 volt coffee maker Slow (only 150 watts), but they do work.
Has anyone completed the installation of this upgrade. I'very got the inverter, cable and 115v outlet but I can figure out how the receptacle is secured in the ashtray area. Went to MB dealer and the parts guy was no help.
