Sponsored by: CARiD
Q on armrest USB port
Old Jan 27, 2022 | 01:57 PM
obaiwa's Avatar
E350
Is the clip behind or on the side of the unit. Thanks again for your quick response. i found the part from a out of state MB dealer.
Old Jan 27, 2022 | 04:04 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
I believe he is referring to the two metal clips on each side of the part you can see in the second photo above?
Old Jan 27, 2022 | 04:22 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
USB Module
side snaps & rear connectors
this looks like a true "media interface" module to convert a USB stream into optical network (aka "MOST").
It is NOT just a straight USB plug to headunit, I thought it was.
MY'14 armrest USB (facing towards back)
This unit does look different... likely has a circuit board too
Old Jan 27, 2022 | 09:04 PM
obaiwa's Avatar
E350
Question USB port
konigstiger, this is picture of my usb hub. the picture looks a little different from the picture you sent to me. Will your part work for my 2016 E350 USB hub ports Vin #WDDHF8JB4GB169068
Old Jan 28, 2022 | 10:29 AM
konigstiger's Avatar
'71 Pinto
Faceplate graphics may be updated but EPC shows as correct part # for your VIN.
https://mbworld.org/forums/e-class-w...ml#post8500824
Old Jan 28, 2022 | 01:21 PM
obaiwa's Avatar
E350
