Help! Sliding on slick road??
Last week the road was a little icy, whenever I tried to drive above 40 MPH I noticed the rear of the car started to slide, and I had to hold the wheels tight to make it drive straight (the sliding warning light did not flash though). But at the same time, most small passenger cars like Toyota or Chevy kept passing me at 60+ MPH, and they were able to maintain control anyway.
Does this sound like a problem? e.g., Alignment issue?
Any comment will be greatly appreciated.
And I feel drive overly cautious are not necessarily safe either, while constantly being passed by many other cars and semi-trucks next lane. I believe it is safer to move with the flow. But because of the sliding concerns, I was not even able to keep up with the flow.
So does it sound like anything wrong with the car from a pure mechanical point of view?
Sounds to me like poor tires losing traction more than anything else.
The Snow tires were bought brand new last year so this is only the 2nd season with them. The thread look at least 9/10 to me.
Had not smacked a curb lately or within the 1.5 years I had the car. It did happen with the previous owner judging from the wheels scratches but it drives OK on dry road.
The other 2 though do not have a date code on them. They do have the same code "DOT K52R JH1R" but no date code behind that like the other 2 tires. They are all the same size 235 40R18 By the way.
Even if driveable, they aren't stoppable.
In the past, I have seen 4WD/AWD cars driving on icy/snowy/wet roads at near the normal speed limit. Later saw them in the median or on side of road where they crashed.
The number one safety feature of any vehicle is the driver acting responsibly.
Sorry for the rant, but all the accidents drive up the insurance rates and take law enforcement and EMS away from doing their jobs.
Just for piece of mind drop by a reputable alignment shop and ask to check your alignment, ie a 4 wheel alignment, the car could be dog tracking
Check tire diameters and place bigger ones in front. This should help to keep rear in check.
On slippery road with the 4 Matic the way it is built it is very important that the tires are the same diameter.
Not sure anywhere other than MB dealer can do the alignment. I hate to spend $200~$300 for alignment but the car did not actually need it.
I thought the rear wheels are generally larger than front? My friend's have 18 on front and 19 on the back.
To test for alignment issue take the car to a large parking lot drive the car then remove your hands from the wheel, of course 10-20 mph see what the car does- straight or veers to one side.
After doing this one way turn around and try to go roughly in the same place and see if the car does the same or veers differently.
You may try with hands off to increase throttle just a bit to also see what is up. Caution when driving without hands off, use caution .
Still thinking alignment!!
FYI my snowblower was tracking to the left, tire pressure was lower on that side, just sayin
If serious alignment issue like bad toe in rear then summer tires would wear showing it.
