Sponsored by: CARiD
Need new Engine - thoughts and advice
Old Apr 17, 2015 | 12:35 PM
Bulldog Creativ's Avatar
e350 Bluetec
I started a new thread (hope that's ok) but it expands on a previous thread...that was a different topic.
1) I need a new engine. E350 2011 Diesel. IT has seized due to oil leak. Not under warranty.
2) I have a local wrecker here that can use an ML diesel block with the rest of my engine components. Apparently there are a few changes (ie. oil pan) but this is essentially the same engine. Is this true?
3) It's hard to fine a whole engine for my model...any suggestions? Or do I truly just need the block?
4) MB here quoted me $31k for a new one. Which is not an option.
Thoughts? Ideas? Prayers ?
PS) I do not need to hear about how it got this way..i just need ideas about how to fix. TY!
Old Apr 17, 2015 | 01:48 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
A friend has used a local independent mechanic to find used transmissions and engine parts for some of his MB cars. Problem for him is it takes a long time to find a compatible part in good condition. Might be worth checking with local shops around you.
The other options that come to mind stem from watching several Sopranos episodes this last weekend.
Old Apr 17, 2015 | 04:53 PM
Diamond White W212's Avatar
2022 GLE 450;
Might try watching ebay for a used engine to come up for sale from a wrecked vehicle. Somewhere there has to be a MB dismantler that has a handful of engines although the diesel would be harder to come by.
Last resort you could sell or part out the vehicle
Might consider calling this place and if they don't have it they could probably point you in the right direction
http://www.mbiparts.com/
Somewhere a few of these cars get totaled and the remaining good parts are waiting for you to need them.
Old Apr 17, 2015 | 06:27 PM
F3LiX's Avatar
w212
yes, essentially the same motor. (OM642) But, as you said, a lot needs to swapped over for direct fit. It can be done, however, I'd ask my self; whats the extent of the damage? Obviously the motor is filled with metal debris if it has seized so it may be a good possibility other components could be compromised. i.e. Timing chain tensioners, cam solenoids, cam covers, heads/cam journals.. Pretty much any small orifice oil has traveled Im not trying to distort your efforts here; just thinking worst case. Which is usually best plan of attack in this scenario.
Green leaf is a good company that has good used inventory
www.car-part.com is a listing site for salvage yards across the country. the web site is terrible (you'll see what i mean) but usually almost everything on there.
Im assuming youve tried jasper? Pretty popular
Good luck man.
Old Apr 17, 2015 | 06:32 PM
F3LiX's Avatar
w212
Originally Posted by thefisch
The other options that come to mind stem from watching several Sopranos episodes this last weekend..
Old Apr 17, 2015 | 06:34 PM
e350 Bluetec
Jasper? Not sure what that is as I've only just begun the search
Thanks for all the advice. Will keep looking.
Not sure what i'd get for salvage on it...as I sad, considering all options.
Old Apr 17, 2015 | 07:20 PM
sghokie's Avatar
2010 e350
Looking on car-part looks like there are 4 engines in the US for ~ $7500.
I think you should look to get a complete engine vs just a block. I think you would need to probably replace the heads as well. If the heads starved for oil too then they would have their own issues too. You would need block + heads.
Also I think labor would be cheaper as well if the heads are already attached.
Old Apr 17, 2015 | 11:35 PM
e350 Bluetec
Thanks - i saw those too.
For that price do you think that's the block and head?
I'm confused as to what is what, to be honest.
If i am just buying the "long block" what is that?
Old Apr 18, 2015 | 06:25 AM
F3LiX's Avatar
w212
Long block is the block with cylinder heads as an assembly. Short block is without heads
Old Apr 18, 2015 | 06:27 AM
F3LiX's Avatar
w212
Jasper is a company that re-manufactures engines and transmissions
Old Apr 20, 2015 | 03:38 PM
e350 Bluetec
was hoping that there is someone viewing that can advise...
I have found two possible engines, both of which need to be shipped to me from Europe.
1) The first a remanufactured long block.
2) The second is a low KM. engine (like less that 2500k)
My main fear is ordering the wrong engine.
My engine model is 642.850.
The remanufactured one matches this, and since the ancillaries will be taken off my existing engine, I think this is fine.
The slightly used one is the same engine number, but from a CLS (which I guess in Europe HAS the diesel option)
I'm hoping someone with some insight and MB know how will be able to help me make an informed decision.
I'm leaning to the LOW KM one as it's cheaper but need to know it will fit without issue.
THanks!
Old Apr 21, 2015 | 07:33 PM
DJ Hellfire's Avatar
2013 E350 Sport
T
As in $31,000????
Why not just go through insurance?
Old Apr 21, 2015 | 10:16 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
Does MBUSA not have a remanufacturing center?
http://www.mercedes-benz.ca/content/...sed_parts.html
EDIT: it appears that they do - http://www.mbusa.com/mercedes/servic...factured_parts
Old Apr 21, 2015 | 11:28 PM
2022 GLE 450;
Originally Posted by DJ Hellfire
As in $31,000????
Insurance does not cover mechanical breakdowns, only collision, comprehensive, and liability.
Unless you are suggesting that his car mysteriously burn to the ground?
Old Apr 22, 2015 | 09:17 AM
RA72825's Avatar
As in $31,000????
That's funny
Old Apr 22, 2015 | 09:25 AM
PeterUbers's Avatar
You have my thoughts and prayers
Good luck
Old Apr 22, 2015 | 11:14 AM
Arrie's Avatar
THanks!
Almost all car models come with diesel engine option in Europe.
How much cheaper is the low mileage one? If not a big difference I would go with the re-manufactured one. It basically is a new engine.
Old Apr 22, 2015 | 06:48 PM
MBSebas87's Avatar
C300 Sport 4Matic
Good luck
+1
Old May 4, 2015 | 01:57 AM
Kevin1992's Avatar
W209 Cabrio
Hello there. Prices in my country (The Netherlands) are about 2.000 to 4.000 euro for a used engine. Thats excluding shipping - not sure on pricing when it comes to that. Here's the link: https://www.onderdelenlijn.nl/voorra...nderdeel=motor
There's only one on their website atm.... Says 'call for price' and has 125.000 kilometers by Auto Wessels (+031 (0) 541 555 141)
If you can figure out dutch that is Hope you find some sort of an engine from somewhere!
Dollar - Euro exchange course is in your advantage atm :P
Old May 4, 2015 | 02:02 AM
Kevin1992's Avatar
W209 Cabrio
In regards to your options you already found... The CLS engine will need mounts etc. which might add costs as well. If the re-manufactured engine is pretty much 'drop-ready', even tho more expensive (we dont know by how much?) that might actually be cheaper and have less downtime?
Old May 4, 2015 | 01:01 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
I would start with the build card.
It will tell you exactly which engine you have and you can go from there.
