6 or 8 piston calipers upgrade
I think you might get more information from the AMG forums about brake upgrades, but anyway wishing you good luck with your upgrade.
If you are doing 40MPH and you slam on your brakes and are able to lock up the tires, you have sufficient braking power. Adding bigger brakes not properly designed for your vehicle can actually prevent you from stopping as well as you do now.
The key to better braking performance on the street is to have Solid rotors that are vented (Not drilled or slotted) as you need the maximum surface area for your pads to grip. Along with some great quality pads (Ferrodo makes the best, OEM is great too). Most IMPORTANT is to have GREAT tires, if your tires can grip you will stop WAY better.
I have been there and done exactly what you are talking about and let me tell you, an E350 will not be able to out accelerate its brakes. You are about 200HP short of needing a serious upgrade.
Also, for an E350 to go from 130mph to 155mph will take an absurd amount of road. The wind resistance is too great to get there at any speed above crawling.
Sell your car and buy yourself a Z06 Corvette or a CTS-V if you want to just go fast. The E350 is NOT a sports car.
For actual functionality, you'll get the benefit of much more even pad wear between the inner and outer pads due to the fixed caliper design. With these types of brakes, the actual caliper does not move at all to provide the stopping power, only the pistons move. So as long as the calipers are not defective or damage internally, the inner and outer pistons will provide equal brake pressure to the pads promoting much more even wear on the pads and more consistent braking over time.
With the standard brakes, the calipers use a sliding method with pistons only on the inside pads. This style relies on the caliper to slide in order to provide pressure to the outside pads. In order for this to operate efficiently, the caliper sliders must be well lubricated and free of dirt. But over time and from heat and moisture, these sliders get sticky, rusty, and sometimes seized. When this happens you're only getting brake pressure on the inside pad where the piston is actually moving because the caliper is unable to slide properly to use the outer pads, which results in poor braking and uneven pad wear over time.
This alone makes the fixed Brembo style brakes worth it for me. But they are just too expensive for what I'm personally willing to spend. But if you have the money and are in good financial standing, go for it. Just don't go into it thinking you're gonna get a bunch more stopping power, because you're not. People spend thousands on wheels, suspension and body kits just for looks. Just because you want to spend the same on brakes doesn't mean it's a waste of money. Do you!
Have some questions about replacing the OEM front calipers and rotors with larger OEM or aftermarket components.
Are the E350 front spindles designed to accept these larger calipers and rotors? Since the E350 has a single-piston sliding caliper and the E55 and E63 have multi-piston calipers (and larger rotors) - wouldn't the spindles require replacement? At least the dust-shields would need replacement for the larger rotors - along with brake lines and hangers - probably other assorted hardware.
Can the existing E350 ABS braking system properly accommodate such a change? Will the master cylinder be sufficient and correct? Are there proportioning valves and/or other critical brake system components that can be effected?
Without changing the rear calipers and discs - wouldn’t the front/rear braking force be changed enough to have a negative effect on vehicle dynamics? (also relates to ABS function and balance).
Changing the existing front brake calipers and rotors on the E350 for improved braking may not be so straightforward. It would also seem that any increase in braking force will require a corresponding increase in traction through tire/wheel replacement to be of benefit.
There's a lot of engineering in the OEM brake systems. Personally – I would leave the brakes alone (unless all these questions can be answered first - and possibly even then).
J.
Edit/Add: Quick check shows the same Mercedes P/N for the 2014 E350 "Knuckle" (spindle) and for the 2014 E63S (both w/o 4-Matic) - also the same P/N for the brake master cylinder. P/N for the 2014 E550 Knuckle was different. Very interesting - makes sense from a production standpoint to use similar hardware where possible. Maybe the upgrade - however expensive - is actually a bolt-on. Guess it would make sense to do the rears at the same time.
Still - would likely be better to simply trade-up to an AMG if the E350 isn't stopping well enough (and/or slow down on the open road).
