Can I change my E550's main battery myself?
I’ve replaced the auxiliary a couple of times over the past 3 years, no big deal. It’s relatively new (yet I hardly ever get the green light for eco start/stop in general).
MB or aftermarket? And what’s this “reset” business about? Mine is a 2014.
many thanks!!!
many thanks!!!
many thanks!!!
Anyway, AutoZone installed the battery and the guy used some sort of a “battery” connected to the OBD port while the main battery was disconnected. He said this prevents the car computers from losing memory.
A few months later I went to get the car inspection but they could not read the codes. Turned out the fuse for the OBD port was blown. I think that “battery” that AutoZone guy used caused this.
I have disconnected my main battery several times after that when working on the car and never had any problems and have not needed to reset anything else but seat memory positions.
The small battery is used to maintain voltage when the car is cranking. If it doesn't pass the check, the car won't shut off. There are about 80 parameters that can disable an eco stop/start action. Either battery can be the cause.
