10mm Front wheel spacers won't fit?
The problem I'm having is I don't see any made for the front of the 2012 e350 sedan. Every website I check says rear only. Any ideas on 10mm spacers for the front without vibration ?
Will those work? I saw another thread(different car) that type of spacer wouldn't fit on front hub and they have a picture of it. Everyone commented that those are for rears only and won't fit over long front hub
https://mbworld.org/forums/c32-amg-c...ers-front.html
You also will need longer lug bolts. I recommend RAD http://www.otisincla.com/ . they are the only company that makes cold forged lug bolts .
I'm not sure...maybe not enough hub left for wheel to sit on? Wish I knew what front hub looked like so I could understand the problem. According to HR website 10mm spacers only fit rear. It shows 15mm fitting front and i dont know what make that fit and not the 10mm.
15 mm from back to other lip of dust cap. I'm guessing that's why HR spacers website says 15mm minimum spacer for front?
I came across this issue with some aftermarket wheels (their hub is not deep enough for these spacers). The only way around it (other than not using spacers, changing wheels or using only 5mm spacers) is to brake off the center caps' tabs and secure it to the wheel from the inside with a quality tape (that's what I've done).
It is 4x the size of the front and probably 3x the original hub the wheel sits on. That's why I was contemplating the idea. I might shave the center caps then. They are Vossen, so metal, not plastic.
What tape did you use? It was my alternative solution to get custom center caps, but not sure how they'll stick as the spacer doesn't leave a lot of room.
