Do wheel spacers affect camber
Spacer away!! I'd much much rather have a well spaced set of rims than 105% perfect camber
If you put on wider tires and kept the center of the tire at original location then spacers should not cause a problem.
Front wheels turn different amount when you make a turn. The inside wheel in the turn has to make more angle change for the turn than the outside one and the sharper the turn the more difference between the front wheels.
If you install 15 mm spacers you move the center of the tire out meaning that the turning radius of the inside wheel gets smaller and for the outside wheel it gets bigger. Does not sound much but in a sharp full U-turn probably can be noticed.
If the problem is what I explained don't spend money for alignment as it would not help any. Get wheels and tires that keep center of the tire at the same as original wheels do.
